Author Topic: Ethanol on M42?  (Read 4923 times)
naika
Ethanol on M42?
« on: June 09, 2011, 10:28:17 AM »
HI Guys
I just bought a Touring 318i swapped with an M42 in France, and I'm considering the Ethanol conversion as it is about half the price of regular gas over here.
Has anyone done this?
I assume I need a chip to modify ignition timing and injector timing as well, but do I absolutely need to change injectors to make up for the additional flow, or increase the pressure in the injecto ramp?
Any info would be useful
Thanks
E30 forever!
Bl0mgren
Ethanol on M42?
« Reply #1 on: June 09, 2011, 10:37:11 AM »
Running e85 on stock injectors with higher fuel pressure. (because inspection)
would recommend bigger injectors..
naika
Ethanol on M42?
« Reply #2 on: June 10, 2011, 08:16:10 AM »
So, I would need to instal something like 240-250cc injectors and a new map for the ECU?
E30 forever!
Ethanol on M42?
« Reply #3 on: June 10, 2011, 11:36:35 AM »
I have no idea about the alcohol (though I'd get that chip to advance timing aggressively).
I just wanted to say that I love those touring wagons.  One of these days I'll be heading over & shipping one back.  US DOT has a 25 year exemption that I'm planning on taking advantage of.
Bl0mgren
Ethanol on M42?
« Reply #4 on: June 12, 2011, 08:29:04 AM »
You need 30-40% more fuel when running on e85.
Car will work without new map :)
romkasponka
Ethanol on M42?
« Reply #5 on: June 13, 2011, 08:08:40 AM »
Imho best way is to buy bigger injectors from turbo car (SAAB 4 cil turbo engine, as I remember they are about 350cc and same size, or audi 5 cil turbo 300cc). Fine tuning could be done with fuel pressure.
E30 318is M42
E36 318is M44
naika
Ethanol on M42?
« Reply #6 on: June 14, 2011, 03:16:33 AM »
Thanks Guys for your input
If I'm not mistaken, the 318is injectors are around 200cc, correct?
So if I would need to get 270-280cc injectors.
Being in France, I'll have to check what cars have those type of injectors.
@Bl0mgren: Can you please elaborate on the fact that I don't need a new mapping? I thought I'd need to modify the ignition a bit
E30 forever!
Bl0mgren
Ethanol on M42?
« Reply #7 on: June 19, 2011, 09:12:44 AM »
Quote from: naika;104561
Car will start and you can drive it. If you want engine to run fine and gain hp with good fuel consumption you should consider a remapp of course :)
