Author Topic: Right turn signal buzzing  (Read 2769 times)
gravyface
« on: May 24, 2011, 11:10:29 PM »
Hit a bit of a bump, right turn signal immediately stopped working and is now omitting a wretched "eeeeeeee" buzz sound when on.  Left works fine.  Relay?  Fuse?
« Last Edit: May 25, 2011, 06:51:51 AM by gravyface »
gravyface
« Reply #1 on: August 13, 2011, 07:08:53 AM »
So I've replaced all the bulbs (PO put wrong bulbs in the rear; contact on bulb had a groove melted in it) and keep blowing fuse #4 (tried pulling fuse #25 too as read that hazard switch can be a cause of this).  Left works ok, right signal makes an awful "eeeeeeeeeeee" sound coming from the dash or steering column.  Never heard anything like it before.
Any ideas?
« Reply #2 on: August 13, 2011, 07:54:33 AM »
I'm just guessing here, but that sounds like the undervoltage relay is kicking on.  Check the wiring for a short, especially on the one with the melted connector.  I'd also check to be sure the battery has over 12vdc.  If you have a body harness short it'll be draining the battery quickly.
