Author Topic: Temp Gauge reading Colder than normal?  (Read 2568 times)
H8Rain
« on: May 23, 2011, 05:23:49 PM »
So here's the deal.  Took a 200 mile trip.  During the entire trip, as I cruised at around 70mph the temp gauge read slightly colder than normal (needle was at about 10 o-clock).  When I would get stuck in some traffic and idle or drive about 10mph the temp gauge would go up to normal (needle at 12-noon).
I'm used to overheating issues, but this ones got me confussed?
Any suggestions?
MikeDE
« Reply #1 on: May 23, 2011, 05:33:21 PM »
Most likely t-stat is getting sticky, I have had some also that have stuck open.  My E36 M3 would barely get above 1/4 when this happened.  I just swapped one on an E46 323i that was stuck open.  And my 318i(M40) was like that when I bought it.
monty23psk
  • -Receive: 17
« Reply #2 on: May 23, 2011, 10:57:09 PM »
Seems normal with a lot of air hitting your engine constantly. Mine does this and has new tstat and temp coolant sender.
« Reply #3 on: May 24, 2011, 07:11:05 AM »
How long does it take to heat up?  That'd be the easy way to check the thermostat.  You could also do a temperature resistance test on the sensor...those don't last forever.
« Reply #4 on: May 24, 2011, 12:55:15 PM »
It is most likely the thermostat. They usually fail open & run the motor cold (which is better than the alternative).
If you do replace it, make sure to use the 88C one, not the 80C one.
