Hey everyone,
Need some help with my newly installed throttle cable. I just did a top end rebuild and my idle has been rough for the last month. I wanted to start to troubleshoot it as it was perfectly smooth before the rebulid. Besides the rebuild I did the heater plate delete which of course can be related to the idle problem. The car works great, has nice power but just rough at idle unless I bump the idle up. But with age, my throttle cable has seen better days and has been getting stuck. So I decided I needed this fix as my gas mileage was being affected also and does not help when you are troubleshooting the idle issue. It will get stuck at almost 1500 when letting go of the gas and would hav to reach down to pull pedal to bring it back down. So I swapped it out yesterday, not hard, and now need to know what is correct. I know the specs have the idle on the m42 to be 850+-40 in the bmw e30 factory manual.
Not really finding the answers on this forum in the search. Is there a setting I should have the cable at, regarding RPM? From researching it looks like the throttle plate should be closed at idle, is this correct? Maybe I need to make sure throttle is WOT when pedal is all the way down. Lastly, is the RPMs suppose to increase when I hit the AC button? Before the rebuild, idle was smooth with or without AC. I need the pedal working at best at it could before tracking down the rough idle.
TIA
