Author Topic: FS: 1992 BMW 318ic Convertible NY/NJ/CT  (Read 3456 times)
aworthybrother
« on: May 16, 2011, 06:02:19 PM »
1992 BMW 318ic
2-door Convertible / Cabrio / Vert
e30 Model
144,000 original miles
2nd owner
Vin # WBABA7310NEJ13943
Located in Pelham Parkway in the Bronx
$ 5,700.00
5 speed manual transmission
VERY CLEAN interior
PERFECT CAR for the season...
Purchased this car 2 years ago with 134,000 miles. I have only driven it for only approximately 10,000 miles within this period. This car has been parked in an indoor garage under my ownership. The toy car has to go because we just had a baby and want to replace this with a wagon.
Parts replaced / installed within 8,000 miles:
- MarkD chip
- New Front & Rear Bilstein Touring shocks with M3 springs
- New OEM Front and Rear shock mounts
- New 15 mm drop hats
- New Ignition Coil, Coil Over Plug kit
- New OEM control arms
- New OEM tie rods
- New OEM M3 control arm bushings
- New front and rear Axxis PBR Metal Master Brakes
- New A/C blower resistor pack
- New aftermarket fog light lenses
- NEW HID low beam
- NEW HID yellow fog lights
- New OEM front IS lip
- New water and vacuum hoses (replaced 500 miles ago)
- New Belts (AC, Alternator, Fan) (replaced 500 miles ago)
- New OEM Themrostat (replaced 500 miles ago)
- New OEM Waterpump (replaced 500 miles ago)
- New Leather shift and ebrake boot
- New antenna mast
- New K&N air filter
- New REAR Plastic Window
- New OEM Euro Bumper trim
- New valve cover & intake manifold gaskets
- New Bosch Battery
New Parts NOT installed included in sale:
- NGK (BMW) Sparkplugs
- Timing chain tensioner
- Fuel filter
- Crankshaft position sensor
- Camshaft position sensor
- Throttle position sensor
- Throttle cable
- Coolant Temp Sensor
Other information:
- A/C and heat works 100%
- Powder coated valve and intake manifold covers
- 3rd brake light deleted. Original trunk lid will be included in sale
- Alpine headunit with amber lights and ipod connector
- 10" Infinity Basslink Subwoofer and front component speaker with 2CH amp
- Ronal 15x7.5 et 22 after 15m spacer installed (et 37 without spacers)
- Tire threads still at 80% but with little uneven wear so it shakes a little at high speed.
- Rust in the rocker panel (both sides) and rear valance were grinded down, treated and fixed
- Front passenger side fender is DOT-R (replaced)
- Clutch is a little weak may need replacement but still driveable
- Small crack on rear bumper
« Reply #1 on: May 17, 2011, 07:36:08 AM »
Hey man!
GLWS ;)
aworthybrother
« Reply #2 on: June 01, 2011, 10:27:03 AM »
vonkamp
« Reply #3 on: June 02, 2011, 08:58:49 AM »
Your car is amazing. Good luck with the sale...
Can I ask you where you got that drink holder?
92 318i Cabrio
aworthybrother
« Reply #4 on: July 12, 2011, 05:52:09 PM »
still for sale
