Author Topic: disable ignition  (Read 2700 times)
eric16v
disable ignition
« on: May 07, 2011, 04:26:44 PM »
so I'm in the process of installing some mustang injectors. Got all the way put back together and noticed a leak I believe between injector 3 or 4. I couldn't really tell. So i'm wondering if there is away to disable the ignition with out cutting power to the pump so i can crank the engine and fuel pump with the rail in place and hopefully find the leak.
eric16v
disable ignition
« Reply #1 on: May 07, 2011, 06:41:59 PM »
anybody?
disable ignition
« Reply #2 on: May 07, 2011, 07:58:47 PM »
Jump the fuel pump from the battery?
eric16v
disable ignition
« Reply #3 on: May 07, 2011, 09:01:30 PM »
ok will try .
thanks
RED IS 91
disable ignition
« Reply #4 on: May 08, 2011, 05:03:11 AM »
Pull the spark plug wires off and crank the engine over.
