Author Topic: OBC question...  (Read 3916 times)
a930rocket
OBC question...
« on: April 05, 2011, 08:23:28 PM »
My OBC (Gizmo to the right of the radio) doesn't work, so I have a few questions.
One, how do I get it out? There's no screws, holes, etc.
Two, what do I do to get it going, diagnose it, etc.?
1991 318is
1987 911 Turbo
carlos318is
OBC question...
« Reply #1 on: April 10, 2011, 03:52:33 PM »
the nuts are on the back of the unit you have to put your hand up behind the dash and you can feel the nuts.
When you don't work what not even light up
OBC question...
« Reply #2 on: April 10, 2011, 04:11:15 PM »
+1
Two ways to get at it:
Pull the glove box, pull the inner plastic partition between the glove box and center console.  Look for the small nuts on the back of the hvac panel, two to each side.  You only have to loosen the inner ones, it'll pivot a bit.
Or pull the buttons from the HVAC panel, take out the two small screws on top.  Then take out the two screws on the bottom.  Carefully pry the air control sliders off, then the pry off the slider cover.  Remove the four philips head screws you'll find.  Pull the panel & take out the four OBC nuts.  I typically take out the center console to make that method easier.
As for fixing it, unless it's just gone dim & you need a spare dash bulb, I'm not sure anyone has had much luck.  Maybe reflow the solder?
a930rocket
OBC question...
« Reply #3 on: April 10, 2011, 04:17:39 PM »
Thanks for the advise.
It's not killing me that it's not working, but I'll get to it one day.
1991 318is
1987 911 Turbo
monko141
OBC question...
« Reply #4 on: April 10, 2011, 07:40:04 PM »
If you have a 13 button you have to do what Dave and Carlos said.  If you have a 6 button you can simply pry off the face plate and then you have two clips on the top and bottom that need to be compressed and it just pops out.
a930rocket
OBC question...
« Reply #5 on: April 11, 2011, 10:21:27 AM »
So monko, are you saying that I can pry off the face plate of the 6 button OBC without all the disassembly?
That would make it much easier to get to and I'd fix it sooner.
Jim
1991 318is
1987 911 Turbo
monko141
OBC question...
« Reply #6 on: April 11, 2011, 07:35:02 PM »
Yes.  It's just a thin piece of plastic.
a930rocket
OBC question...
« Reply #7 on: June 18, 2011, 06:05:49 PM »
Follow up: I was working on the radio and went off on a tangent looking at the OBC. I pulled the faceplate and saw the two clips monko was referring to. I pulled the OBC out and it wasn't connected to any wires. That one reason it doesn't work! :rolleyes:
Plugged it in and it works! Just needed to secure the connector better and next buy a left side brake duct so I can install the temp probe to get the temp working.
Anyone have the left side brake duct for sale?
1991 318is
1987 911 Turbo
OBC question...
« Reply #8 on: June 18, 2011, 06:25:55 PM »
I have a duct in metallic tan, but there's this problem I have with finding anything.  I'm not sure the sensor fits in the duct though...I think it clips into the bumper housing.  I'll check it out next time I'm in there.  Hopefully that'll be soon, I have some US ellipsoids to install.
