FS: 91 318i, Alpine White, CT
Author Topic: FS: 91 318i, Alpine White, CT  (Read 2206 times)
mrmckie
« on: March 24, 2011, 08:19:58 AM »
ok so here’s the rundown, bought it in Nov from a dude that said it wasn't running right.  I figured out the problem was a couple of vacuum leaks and the coil packs were bad. I did a comp test and they were all between 200-220. I fixed the leaks, bought a COP kit and replaced the CPS and  it fired up and drove beautiful for a little until one of the coolant hoses under the IM broke on me on the highway. After replacing that, the car doesn’t want to start anymore.  It cranks and idles for a sec then dies.  I’ve put new IM gaskets, spark plugs and tried a new ICV and AFM and neither made a difference.  It’s getting gas b/c the plugs are wet so it may be a spark problem or even more…
I have no time to work on this car anymore as I bought a new car and I have an 86 325es project car that I want to focus on. I haven’t recv’d the title from DMV yet as I just registered it in the beginning of Feb though, you can submit a lost tile form w/ DMV so you can at least register it.  I’ll try to get it running again but I would tow it personally.
Asking $600 obo. Will trade for a good turbo setup for my 2.7 stoker motor
Body:
-189,xxx miles, clean title
-Alpine White
-Body Panels are pretty straight except the hood(dent), front bumper(crack) and lower valence(dent)
-rear valence has rust by the tow hook
-there’s rust under the battery tray
-I didn’t have a chance to wash it but the paint looks pretty good.
Interior:
-Blue cloth
-no radio/speakers
-heater control does not slide to hot and only works on 4
-comfort seats are torn
-no radio/speakers
-couple misc panels need to be replaced
-drivers side lock doesn’t work w/ key, it has to be closed from either the trunk or passenger side
Suspension/Brakes:
-I know your definitely going to replace the bushings all around
-Shocks feel ok.
-new rotors included, just need pads
-the drivers side caliper looks to be seized
-no P/S
-17” RP-F1 replicas in gunmetal w/ chrome lip, not in the best looking shape but they look nice on the car, the fronts don’t fit though, offset was too high.
Engine:
-Had good compression pre break down
-didn’t see any coolant in the oil, and I didn’t notice any new oil leaks after an oil change
-new NGK Plugs
-new IM gaskets
-exhaust is in good shape
-extra AFM and ICV included
-aftermarket intake(previous owner installed)
Extras for sale
-new COP Kit
-new catalytic convertor - $150
-Cardinal Red door panels - $150
-front black vinyl comfort seats - $50
I'll try to take get better pics tomorrow or Sat when it's sunny.
