Author Topic: rear camber/toe correction  (Read 3518 times)
B318M42W
« on: March 22, 2011, 03:45:09 PM »
Just got the tie rods changed and the alignment guy showed me how crooked the rear end was. REALLY bad for the right rear... so how can i get it right?  didn't touch the rear suspension yet. only the subframe bushings were done 3 years ago when i got the car. I think it has -2.5 degree camber and -1.5 on the other side. don't remember toe, but it was some bit too.  Oh and the rear suspension is possibly collapsed, but still works.
My options? (not a millionair either...)
oh and started front wheel/s started to shake pretty hard upon braking, fresh out of winter storage for 5 months... ideas?
« Last Edit: March 22, 2011, 04:28:59 PM by B318M42W »
M90 Blown M42 :cool:
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #1 on: March 23, 2011, 01:24:37 PM »
If your rear suspension settings are off side to side, you most likely have a bent trailing arm (it's not that uncommon). If your car is lowered, the suspensions settings will naturally change which is not really a problem unless its different side to side.
You can get toe/camber correction eccentrics from AKG or Ireland Engineering. You must weld these in though.
-Nick
91 E30 M42 with VEMS
