Author Topic: Roof lining  (Read 4583 times)
carlos318is
Roof lining
« on: March 19, 2011, 04:28:37 AM »
Does anyone know how easy it is to remove the bit of headlining that is in between the rear window and the side window on a E30 coupe and then put it back nice and tight :D
DarioM42
Roof lining
« Reply #1 on: March 19, 2011, 08:02:28 AM »
carlos318is
Roof lining
« Reply #2 on: March 21, 2011, 12:00:11 PM »
Has anyone removed the head lining
Roof lining
« Reply #3 on: March 21, 2011, 08:25:19 PM »
I (sort of) did it once on a coupe with the rear window broken out.  The lining is retained by the window seal around the mounting flange.  IIRC you'll have to remove the plastic trim inserts, then the rear window, then the rear window seal, then finally the fabric headliner.  It's not impossible, but definitely a lot of work to get it right.
I also use a bit of fabric adhesive to keep the headliner in place long enough to mount the seals, especially on the sunroof and rear door seals.
Roof lining
« Reply #4 on: March 22, 2011, 05:34:28 AM »
I did, pics are here. The headliner is glued in place underneath the windows - you'll have to pull the windows to fix the headliner.
