Author Topic: Chain tensioner question...  (Read 2328 times)
a930rocket
« on: March 18, 2011, 09:25:14 PM »
Doing a search, I found a picture of what appears to be the timing chain tensioner and it's accessed from the outside. Can I just pull the bolt and replace the tensioner?
Thought this might be a good safety item while working in other things nearby.
1991 318is
1987 911 Turbo
rjcaptsean
« Reply #1 on: March 18, 2011, 10:41:01 PM »
The 19mm hex just above the A/C bracket is the tensioner cap. Take that off, and the tensioner resides inside.
Not sure what you mean by "good safety item while working in other things nearby".
a930rocket
« Reply #2 on: March 19, 2011, 09:34:22 AM »
Sorry. Should have a little more clear. I was thinking as long as I was in the area of the engine working on things, it would be easy to swap out the tensioner as a preemptive measure until the day I dig into a timing chain,etc redo. I'm guessing I have a 20 year old chain, even if it only has a 142k miles.
Quote from: rjcaptsean;102407
1991 318is
1987 911 Turbo
« Reply #3 on: March 19, 2011, 10:02:29 AM »
I'd hold off until you're sure of the condition of the chain, guide rails and cam sprockets.  I've heard of a few cases that putting a new M44 tensioner onto an old timing chain quickly wore the guides out.  The guides were revised as well.
a930rocket
« Reply #4 on: March 19, 2011, 02:27:54 PM »
I hear ya. Install something new and the surrounding old parts crap out.
1991 318is
1987 911 Turbo
