Author Topic: M42 Engine Parts  (Read 6869 times)
Drewdown
M42 Engine Parts
« on: March 18, 2011, 04:48:01 AM »
Hey guys, I have some parts left over from a blown engine out of a 91 318is.  Im kind of a noob when it comes to m42s so try and work with me as best as possible.  Prices are going to be a rough estimate based on what other people sell for... if Im way off base just let me know.  Also everything is OBO :D
Parts are located in the Bay Area, California
Oil Filter Housing - Make me an offer
Headers - Best offer on this one too
Lower Intake with Injectors and Fuel Rail sold
Throttle Body -sold
Upper Intake Manifold sold
AC Compressor - 30 The outside of the pulley is dinged up as you see in the pic... shouldnt  effect it though :dunno:
DSC_0923.jpg by Drewdown49, on Flickr
DSC_0924.jpg by Drewdown49, on Flickr
Power Steering Pump - 25
DSC_0927.jpg by Drewdown49, on Flickr
Alternator -sold
Throttle Body Heaters - Dunno if anyone actually keeps these so 2 bucks for the one without a lower part and 4 for the full one
Crank Pulley - 10
Harmonic Balancer - 10
ICV - Sold
Thermostat Housing - 7
Valve Cover - Sold
Coil Wiring - 15
Tranny Plate thing (Sorry I forget the name) - 5
Cam and Crank Timing sensors - 10 each
I still have basically the whole bottom end.  The block and the crank are gone but I might be able to salvage other parts.
« Last Edit: June 01, 2011, 01:25:30 PM by Drewdown »
Drewdown
M42 Engine Parts
« Reply #1 on: March 18, 2011, 01:12:27 PM »
Upper and Lower Timing Case Covers - 15 each
Crank Pulley - 10
ICV - 10
Valve Cover - 25
Coil Wiring - 15
Okay so now comes the tricky part... I Have a whole head assembly from the engine that blew.  The cams are in good shape  and none of the valves appear to be bent.  Sorry I cant describe the condition of this thing very well, but I can take a lot of pictures, so just ask :rofl: The piston on cylinder 2 went out, so the head got a small nick as you can see here in the upper right corner:
Overall pics
Cams
The head can either be sold complete with cams and everything or parted out.
One last thing not pictured sorry
Prices are flexible... and if there's anything I didnt list that you might need form an engine just ask... I might have it.
hnilsen
m42b18 parts
« Reply #2 on: March 27, 2011, 02:04:03 PM »
I realize this is an old post, but wondering if you still have the a/c compressor and power steering pump? Would you take $25 a peice for them?
hnilsen@canalbarge.com
Drewdown
M42 Engine Parts
« Reply #3 on: June 01, 2011, 01:24:23 PM »
bump
M42 Engine Parts
« Reply #4 on: June 01, 2011, 02:34:32 PM »
I approved your 2nd post so you can merge or delete it.  I must have missed it the first time.
Artem
M42 Engine Parts
« Reply #5 on: June 01, 2011, 03:53:14 PM »
Please write to Artem dot Lepilov at gmail dot com, I need a few pieces you got. Specifically, the throttle body pieces and maybe the ICV.
Thanks!
________________________
Artem Lepilov
WPI Aerospace Engineering
Class of 2008
M42 Engine Parts
« Reply #6 on: June 01, 2011, 07:39:57 PM »
Any chance you have the front exhaust support bracket parts (the stuff that bolts to the bottom of the tranny & holds the downpipe)?
e30work
M42 Engine Parts
« Reply #7 on: June 03, 2011, 12:11:34 AM »
do you have an upper oil pan? thanks
carguy101
M42 Engine Parts
« Reply #8 on: June 28, 2011, 10:45:56 AM »
How well does the a/c compressor work?
ClayW
M42 Engine Parts
« Reply #9 on: June 30, 2011, 09:30:11 AM »
Still have the Thermostat housing? Compressor?
Project Blogs:
1967 BMW 1600 w/M42: www.tx02.blogspot.com
1991 BMW 325i DD: http://www.r3vlimited.com/board/showthread.php?t=266953
ApexGoblin
M42 Engine Parts
« Reply #10 on: July 16, 2011, 03:27:39 AM »
still have the exhaust manifold? and where are you located?
Carter
M42 Engine Parts
« Reply #11 on: August 02, 2011, 03:31:24 PM »
Are the cam gears, crank gear, and lower guide in good shape?  If so I'll take them!
stillmatick
M42 Engine Parts
« Reply #12 on: August 02, 2011, 07:05:30 PM »
is that a denso compressor?? if so i take it.
sailer6460
M42 Engine Parts
« Reply #13 on: August 28, 2011, 10:06:28 AM »
PM sent
I\'ll tell you what the man who fell from the 40 story building said as he passed the 20th floor................... So far so good.:cool:
