Author Topic: Do You Have Jittery Guages?  (Read 5346 times)
dgdavidson
    • http://www.gnegy.com/reynard
« on: September 28, 2006, 09:59:50 PM »
My water temp and fuel guages have been intermittent and shaky since I got the car about 2 years ago.
The odometer quit so while I had the cluster out to replace the gears I took a look at the two trouble makers. Found that they just clip into the circuit board yet have a threaded shaft that sticks through the back of the cluster. The threaded shaft is part of the electrical circuit and there is a pad on the circuit board for it.
I cleaned up the contact pads and found two nuts and washers of appropriate size and locked the two guages down. So far not a jiggle out of either guage.
Also, while I had the cluster out, I spliced in two wires into the blue connector harness and added an additional low oil pressure light that lives next to the rear window defrost switch.
One of these days I'll install a proper oil pressure guage.
Hope this helps someone.
1991 318is Diamant Schwarz
Deutschbag
« Reply #1 on: September 28, 2006, 10:40:25 PM »
Sweet, I'm gonna take a look at mine when I get a chance. My fuel gauge sucks ass.
automatic
« Reply #2 on: May 13, 2007, 08:20:40 PM »
Quote from: dgdavidson;12421
How did you replace the gears in your odometer?
FL318is
« Reply #3 on: May 13, 2007, 08:55:36 PM »
DIY please!
sports.racer
« Reply #4 on: May 15, 2007, 10:03:15 PM »
Quote from: automatic;25658
Bought the gears here...   http://www.odometergears.com/subpages/bmw.html
There's a site somewhere with a good how to on this. Thought I had it bookmarked but can't find it. Sorry.
sports.racer
« Reply #5 on: May 15, 2007, 10:06:14 PM »
Quote from: FL318is;25662
DIY please!
Don't have any pictures or anything but once you pull the cluster apart you'll see exactly what's needed. The gauges just clip into place. Carefully pull one out and take it to the hardware store to get the right size nut and washer.
