Author Topic: Misc questions...  (Read 5581 times)
a930rocket
Misc questions...
« Reply #15 on: March 16, 2011, 08:12:50 PM »
Went to swap out the fuel filter and noticed the lines were ozone damaged/cracked. Had to go get new fuel line to do it right.
While I was under the car, I noticed there was an orange label on the front bottom if the trans. It said:
ATF-OIL!
Automatic Transmission Fluid
I wouldn't have guessed it, but you learn something new everday!
1991 318is
1987 911 Turbo
a930rocket
Misc questions...
« Reply #16 on: April 06, 2011, 04:43:50 PM »
Follow up on the One Touch Window control and posted on the Interior Forum as well.
I ordered it from Amazon: http://www.amazon.com/AutoLoc-WC2000-Touch-Window-Windows/dp/B003PI77XW/ref=pd_ys_iyr_img
I bought the two window kit and started on the driver's side window. After a couple of hic ups (electrical wiring is not my friend), I figured out which wires power the "up" and the "down". You simply cut the two wires and wire the proper 4 wires to each end. Black for "Up" and Purple for "Down". See attached pix.
Also, black for ground and red for power, which I spliced into the cigarette lighter.
The control box, I placed in front of the ash tray, under the console. I had to angle it to get it to work. I placed it there because I didn't think there would be enough room to fit both in the shifter area of the console.
I wired the passenger switch the same, but all I got was a clicking from the control box. Swapped boxes and it worked, so I must have a defective box.
« Last Edit: April 06, 2011, 04:50:38 PM by a930rocket »
1991 318is
1987 911 Turbo
