Author Topic: m42 vs m5x comparisons  (Read 4158 times)
littleboyblues
« on: March 06, 2011, 11:11:51 AM »
Does the m42 and the bigger l6 motors share anys components?
Pistons, wrist pins, rods, valves, sprins, heat bolts....anything?
If there are size similarities can they be swapped? And is there a varience in strength between the years?
Letsplayskatch
« Reply #1 on: March 07, 2011, 02:47:50 PM »
Chalk and Cheese fella
jscribble
« Reply #2 on: March 08, 2011, 07:57:16 AM »
Quote from: Letsplayskatch;102101
Translated, means "No".
Betty - Sold
Sabine - 2004 325xi
Letsplayskatch
« Reply #3 on: March 08, 2011, 01:32:35 PM »
Thanks Sherlock.
littleboyblues
« Reply #4 on: March 08, 2011, 09:42:37 PM »
haha...well i guess that sucks. With more cylinders it means theres more parts in the junk yard.
jscribble
« Reply #5 on: March 08, 2011, 11:19:36 PM »
Quote from: Letsplayskatch;102118
Thanks Sherlock.
Sorry, there's a lot of us on the other side of the pond. Many euphemisms do not come across easily.
Betty - Sold
Sabine - 2004 325xi
romkasponka
« Reply #6 on: March 09, 2011, 01:54:55 AM »
Quote from: littleboyblues;102127
It depends what you want to do. Check http://www.bmwfans.info and mahle website for piston dimensions. By swaping piston you can lower or increase compresion ratio.
http://www.4shared.com/document/rtgcsjZm/engines.html
« Last Edit: March 09, 2011, 02:22:13 AM by romkasponka »
E30 318is M42
E36 318is M44
fiftytakedowns
« Reply #7 on: March 09, 2011, 03:24:09 AM »
the Euro S50b32 I believe is very similar in design.
Warsteiner
  • -Receive: 21
« Reply #8 on: March 09, 2011, 06:55:17 AM »
C'mon guys.......of course we do.
What do you think about the 6mm valves?? They are actually in the M3 too!
http://www.realoem.com/bmw/partxref.do?part=11341739820
How about connecting rod bushings? M3 also! I don't think the wrist pins are the same due to larger diameter in most cases? 84mm vs 86mm bore.
http://www.realoem.com/bmw/partxref.do?part=11241278209%09
There are more with some modifications. I know because I have done them on my stroker motor:D
I have E36M3 valves, pistons, cam trays....E30M3 exhaust and possibly the intake plenum.
So there are definitely parts that can be swapped with or without modifications.
Cheers,
~Ralph
littleboyblues
« Reply #9 on: March 09, 2011, 10:47:57 PM »
bmwfans.info will become my new friend:)
