Author Topic: turn signal fuse  (Read 3561 times)
318lotis
turn signal fuse
« on: February 22, 2011, 09:36:21 PM »
anyone know why # 4 and # 24 are both needed for turn signal, when i have a 15 amp in both slots the # 4 blows and the turn signals stop working.
 But when i leave # 24 slot empty and put fresh 15 amp in # 4, the turn signals work. The car came with a low end after market alarm, i wonder if that would be causing the short?
bmwm42
turn signal fuse
« Reply #1 on: February 23, 2011, 01:48:12 AM »
one thing worth checking out is your hazard switch ie fuse number 24 if that things keeps shorting the fuse for whatever reason and gets no power niether will the turn signals
318lotis
turn signal fuse
« Reply #2 on: February 23, 2011, 12:16:25 PM »
yes, # 24 is shorting out # 4 fuse constantly. your right, this disables turn signals. i am now leaving # 24 slot empty, to enable turn signals to work. I discovered that hazards will not work unless you have 15 amp in # 24 slot. Im certain that the after market car alarm is causing this problem.
turn signal fuse
« Reply #3 on: February 23, 2011, 01:53:51 PM »
Is there a parking light blinker on the alarm?  You might be right...the transistor in the alarm that blinks the lights is usually wired into the emergency light switch.  If it died it could short the emergency light circuit.  Can it just be pulled?   I know the stock BMW Alpine can.  That's pretty high on my to-do list for old BMWs I buy.   Those alarms never last.
« Last Edit: February 23, 2011, 01:56:10 PM by DesktopDave »
steel330i
  • Half the cylinders, half the problems?
turn signal fuse
« Reply #4 on: February 24, 2011, 11:21:18 PM »
sorry to somewhat jack your thread, but im having the wierd signal issue also with my left signal, so if i look into the fuses, but is there a relay for these signals as well? thanks
-Travis
In pursuit of perfection...just not in a Lexus
