I do not have what you are asking for, persay, but I can tell you what it uses those inputs for.
The throttle tells it a couple things:
1) whether to use idle maps, part throttle acceleration/coasting maps, ot full-throttle maps
2) it is part of the engin eload calculation which is an integral part of the fueling & spark maps
The AFM tells the ECU the ambient air temperature and volumetric flow rate of air into the motor. From these it calculates the mass flow rate and uses as the primary input for the load calculation.
