Author Topic: Modifed M42 engine  (Read 3589 times)
gtatbrissy
Modifed M42 engine
« on: February 05, 2011, 06:52:25 AM »
Hi all
selling up my m42, gearbox and driveshaft. everything is still in working order and currently still in the car. engine has 225k on it, gearbox has 140k and clutch and flywheel have 10k. flywheel is a lightwight bmp design item, clutch is a excedy heavy duty. i have changed to oil and filter every 2500ks, use castrol full synthetic oil. exhaust is a custom 2 and 1/4 stainless steal main system and custom made 4-2-1 headers. i have someone interested in the exhaust already. the rocker cover and front crank seal are leaking but i will replace them before sale. also i have custom made alloy pipe that bypasses heater core and throttle body heating, so no mess under the intake.
as i am a mechanic i can rebuilt the engine (new bearings, rings, gaskets, timing gear, etc) at new owners expense. i live in brisbane, australia. i will ship if buyer arranges and pays. i can put engine and gearbox in crates as i am getting a new motor soon.
looking for around $3000 for everything, but i will sell major items seperating at the following cost.
clutch/flywheel ($1100 new) - $600
exhaust full ($1700 new) - $1000, headers ($900 new) - $650
gearbox - $500
engine without exhaust, clutch/flywheel - $1000
ecu - $200
wiring harness - $100
if you want anything else seperate, throw me an offer.
all prices are negotiable
Brian318is
Modifed M42 engine
« Reply #1 on: February 05, 2011, 08:06:18 PM »
What kind of clutch and flywheel is that?
gtatbrissy
Modifed M42 engine
« Reply #2 on: February 06, 2011, 04:06:10 AM »
exedy heavy duty clutch built by npc clutches at archerfeild (have recept)
http://www.exedy.com.au/HeavyDutyClutchKit.aspx
bmp design flywheel 9 pound
http://www.bmpdesign.com/product-exec/product_id/1191/category_id/47/search_year/1990/search_model/31
Brian318is
Modifed M42 engine
« Reply #3 on: February 06, 2011, 01:52:57 PM »
Is anything else needed to install either of those, or is it pretty much bolt on?
gtatbrissy
Modifed M42 engine
« Reply #4 on: February 06, 2011, 09:15:31 PM »
Nop it is a direct replacement... makes a big difference from 4000 rpm onwould
