Author Topic: M42 engine and transmission parts  (Read 27028 times)
dunny
« on: December 28, 2010, 10:25:27 AM »
Old post, but I still have the parts listed below as of 5/2/14.  I need to raise funds for some maintenance work on the 318i so email or message me if you are interested.
Valve cover - $50 shipped
Rods/Pistons - Make offer
Block - Make offer
Pulleys/misc - Make offer
Transmission - $150 picked up unless buyer pays shipping
Wiring Harness - $100 shipped
2 stock shifters / knobs - Make offer
ICV - $40 shipped
Cams - $100 shipped
Cam gears (may not be any good though) - Make offer
mounts - Make offer
radiator (the bleeder port is boogered up a bit but otherwise its usable) - $50 plus shipping
Coil Pack & wires - $50 shipped
Stock 14" steelies and hubcaps - Make offer
Exhaust manifold - Make offer
AC Compressor - Make offer
Crankshaft damper/gear - Make offer
« Last Edit: May 01, 2014, 11:25:33 PM by dunny »
dunny
« Reply #1 on: January 05, 2011, 12:01:32 PM »
I will part/split up, so let me know if you need anything!
« Reply #2 on: January 05, 2011, 04:22:39 PM »
e30 luck is looking for a transmission.  Is it still in the car?  I can get you his number if you like.  Cincinnati is a haul from Pgh though.
dunny
« Reply #3 on: January 08, 2011, 03:35:05 PM »
I pulled the engine/trans last weekend, so it is ready to be parted.  I can take some photos if he is interested.  PM me the number and I'll give him a call.  I can definitely use a little bit of project money as I have quite a few items left to buy to get mine running :)
fiftytakedowns
« Reply #4 on: January 11, 2011, 12:43:37 PM »
will you post some pictures of the Crankshaft sprocket and timing chain Rail guides
dunny
« Reply #5 on: January 13, 2011, 10:19:09 AM »
I'll take some photos tonight
dunny
« Reply #6 on: January 17, 2011, 10:26:24 AM »
« Last Edit: May 31, 2012, 09:37:14 AM by dunny »
dunny
« Reply #7 on: January 17, 2011, 02:46:53 PM »
« Last Edit: May 31, 2012, 09:37:21 AM by dunny »
joshcxcb
« Reply #8 on: January 23, 2011, 01:59:28 AM »
Hey I'm in cincinnati and I'm trying to get my 91 318is back on the road. I need the lower timing chain cover, chain guides possibly, timing chain tensioner, radiator if you decide to part with it. Or if you have any leads on a low mileage motor near us that would be cool too.I had my chain jump a tooth at 127k and bent 15 valves. Im at 147 and the timing tensioner went out and the chain wore a hole in the lower timing cover.
joshcxcb
« Reply #9 on: January 23, 2011, 12:15:18 PM »
I thought i replied but it never showed up. I live in cincinnati (near northside) and im trying to get my 91 318is back on the road. My timing chain tensioner failed so i could use one of those as well as the lower timing chain cover (the chain slapped a hole in the cover) i don't think it jumped any teeth luckily. If you wanna part with the radiator i could use another. Or if you have any leads on a good motor that would be great as well.
Thanks
steel330i
  • Half the cylinders, half the problems?
« Reply #10 on: January 23, 2011, 08:02:55 PM »
how much for valve cover? pics?
In pursuit of perfection...just not in a Lexus
dunny
« Reply #11 on: January 24, 2011, 07:47:27 AM »
« Last Edit: May 31, 2012, 09:37:31 AM by dunny »
AutoXSS
« Reply #12 on: January 29, 2011, 03:07:06 PM »
lower oil pan shipped to 66503, kansas?
sKunk
    • http://www.1320video.com
« Reply #13 on: January 29, 2011, 09:15:10 PM »
both upper and lower oil pans? shipped to 68023?
dunny
« Reply #14 on: February 25, 2011, 06:45:32 AM »
« Last Edit: May 31, 2012, 09:37:41 AM by dunny »
