Author Topic: Zoso's Front Wheel Bearing Replacement  (Read 3934 times)
« on: December 28, 2010, 08:21:12 AM »
Apologies for pretty much stealing this page, but it's so good that we couldn't let it go!  Sorry for the poor quality & missing images, they were very difficult to track down.  Of course, if anyone has problems with me posting this page, please let me know.  We are very ethical and certainly don't support plagiarism.
E30 318i Repair -
  The symptoms of a front wheel bearing gone bad are easy to diagnose. When the wheel bearing is going bad, you can hear a howl coming from the offending wheel bearing. As the bearing gets worse, the howling gets louder. Some other symptoms are that the howling becomes attenuated when the weight is shifted off it. For example, if your driver's side wheel bearing is failing, when you make a sweeping left-hand turn, the howling will be reduced. This is because the weight is shifting to the passenger's side of the car and off the dying wheel bearing. The howling noises will also be speed dependent.
  Luckily for us, the wheel bearings in most E30s last a long time. My front wheel bearings went almost 175,000 miles before I started to hear a slight howl. Many people allow them to get worse before changing them, but I'm very progressive with my repairs.
  Another thing that we should be thankful for is that the front wheel bearings are very easy to replace. The best write up I found on the web is from Randy Walters. I can add nothing to his write up but pictures and my own experience.
Required Parts and Tools:
Part Description & BMW Part   Number
             2xFront Wheel Hub w/ ABS - 31 21 1 131 297
             2xCollar Nut - 31 21 1 125 826
             2xDust Cap - 31 21 1 130 125
          Tools:
             6mm hex wrench
          17mm socket and ratchet
          19mm socket and ratchet
          36mm socket and breaker bar
          Chisel
          Hammer
        Let's begin the procedure! Remember that my 1991 318i may be slightly different than your car. Double check that the part numbers are the same for your exact car.
  Click on the thumbnails for larger pictures.
     Slightly loosen the lug bolts and jack up the car. Remove   the tire. Remove the caliper with a 17mm socket.
     Remove the caliper holder by with a 19mm socket.
     Zip tie the caliper to that loop in the wheel well and be   sure that there is no pressure on the brake lines. The caliper should not   hang from the brake line. Reinstall the screws in the caliper holder so you   don't lose them!
     Using a 6mm hex socket or wrench, remove the 6mm hex bolt   that is holding the ABS sensor. Remove the ABS sensor.
     Using a chisel, remove the dust cap.
     Bend the tab back outwards using the chisel. Spray the   inner race ad the stub axle with a penetrating lubricant such as Liquid   Wrench. Let set and repeat.
     Reinstall the wheel. No need to torque the lug bolts Lower the car to the   ground and with the parking brake set and the wheels chalked, loosen the   collar nut though the center hole in the wheel.
   The collar nut requires a 36mm socket. Before you start this procedure,   make sure that your 36mm socket fits inside the hub. Some people have tried   this procedure only to find out that the outer diameter of their 36mm socket   is too large. If it will fit through the hole in your rim, it will work.
   The collar nut is tightened to around 200 ft-lbs so you may need a cheater   pipe. I'm a stud and the bar was plenty. :) Do not remove the nut, loosen it   until there are
   Jack the car up and support it properly on a jack stand. Loosen the nut so   it is approximately 1/4" away from the bearing's inner race.
     Remove the rotor by unscrewing the 6mm countersunk hex   bolt. The bolt that held my rotors on was frozen and stripped. Nice job   previous owner! I had to drill mine out. I knew this was the case and had   replacement bolts. After drilling them out, a few smacks and the rotor came   right off.
     The goal is to remove the old hub/bearings without leaving the bearing's   inner races frozen on the stub axle. A smart trick that Randy suggests is to   keep the tire on the hub and the collar nut on the inner race and yank on the   tire a few times. If you don't keep the collar nut on the stub axle, make   sure to gather all your broken teeth before you head to the hospital because   you are going to smack yourself in the face with the tire if the hub comes   off. The yanking action will be like a side hammer. Hopefully between this   and the penetrating lubricant, the race will come right off.
   Because I smacked my rotors a few times, I freed the bearings from the   inner races and I didn't do the slide hammer technique.
     My hubs came out with the bearings. Beautiful!
   If your inner race stays on your stub axle, this job gets more difficult.   Your best bets are to use a heat, a chisel, a cutting wheel. Maybe a puller   would do the job too if you could make it fit.
     Take this opportunity to really clean the stub axle, the   rear dust cap, and everything else in there. I had ordered a new rear dust   cap, but I didn't want to force anything getting the old one off and it was   in good condition so I left it.
     Here is the new hub. So shiny! The inside has a nylon ring   that holds the two sections of inner race together inside the hub. Do not   remove the nylon ring.
     Place the new hub on the clean stub axle. Use your 36mm   socket and gently tap the inner races of the new hub onto the stub axle. If   you push on anything besides the inner race, all the races and probably the   bearings will separate from the hub. You don't want this to happen. As you   slowly put the hub on the stub axle, you'll notice the stub axle forcing the   nylon ring out.
     Keep going! Gently. I accidentally tapped too hard and didn't   hit it straight on and one of the inner races popped out. Getting the inner   race back into the hub is supposedly a real pain. The problem is that it   requires even force to pop the race back onto the bearings. To get it back   on, I put it flat on a table and used my 36mm socket to apply consistant   pressure around the race and popped it straight on. It took me 1 minute.
     When you have it all the races on the axle part way, screw   on the new collar nut. Tighten the collar nut with your 36mm socket and that   will push the hub on the rest of the way.
     Reinstall the wheel and lower the car. Torque the collar nut   to 200 ft-lbs.
     Jack the car up again. (I know - up, down, up down..). Use   a chisel and bend the locking tab on the collar nut down. Reinstall the   rotor, caliper holder, calipers, and ABS sensor.
     Tap on a new dust collar.
     Sit back and congratulate yourself for a job well done!
             Performed:
         July 16, 2005
             Mileage
         174,300
Difficulty:
2 /5
  Disclaimer:[FONT="] I am not a professional mechanic. Information this page should be used at your own risk and discretion. Different models and model years may be different than my 1991 318i. Read: If you screw your car up following my instructions, sorry. Isn't it sad that in this sue crazy world you have to put a disclaimer on your web page? [/FONT]
« Last Edit: December 28, 2010, 08:33:40 AM by DesktopDave »
