Author Topic: Zoso's Map Light Mirror Install  (Read 5014 times)
« on: December 28, 2010, 07:31:46 AM »
Again, apologies for posting someone else's work.  If anyone (especially Zoso) has a problem with this, let me know.
 318i Tech Procedure -
Maplight Installation
  The interior of the E30 is very dim. The only sources of light in the E30 are two lights in the back seat area that are supposed to light up the car. What happens if you are trying to look at directions or a highway ticket? There is no way to turn these lights on without reaching back and hitting a switch. It is an awkward movement. When I saw that a maplight was available, I got one right away. A maplight is also a must if you are driving around with a woman in the car. They are always searching through their purse for something or another.
  I bought my maplight on eBay for about $60 plus shipping. This item is a popular modification for E30s and the auctions typically get a lot of traffic.
  Required tool list:
Soldering Iron/Solder (or crimp connectors)
Electrical Tape
Wire
Wire Cutters
Wire Strippers
Female Pins
Click on the thumbnail for larger pictures.
         Here is a picture of the maplight.
         This is a back side and bottom shot of the unit. Notice the plastic knob   near the base? Make sure you the unit you buy has this because this part,   when turned, helps prevent the mirror from shaking. Sometimes these get lost   and then the unsuspecting eBay buyer gets a mirror without one because he   didn't know to look for it. Ask the seller if it has one before you buy if   the pictures don't show it.
         Here is a picture of the stock connector. The easiest way   to wire up the maplight is to reuse the connector. Molex makes a connector   that fits. I was unable to procure one, or cannibalize one that fit so I came   up with my own solution.
         I had these connectors from Radio Shack.
         I soldered two 12" long wire onto two connector, one   with a red wire and one with a black wire.
         The connectors are too loose to stay connected. I took a   pair of needle nose pliers and made the diameter of the female connector   smaller so that it fits the BMW connector very snugly. I did this for both   connectors and then wrapped them in electrical tape to prevent electrical   short circuits.
         Here is a picture of my stock mirror and information panel. I have the   non-check control panel that only displays airbag and seatbelt warning. I   also have a crank sunroof. I checked all these wires but there is no switched   or constant 12V source in this wiring connector. For those of you with an E30   like mine, we're going to have to route power from elsewhere.
   For all of you with a check control panel, use the following pins for   power and ground:
   Pin 9 = Ground
  Pin 15 = Constant 12V
  Pin 23 = Switched 12V
   You should double check these pins with a multimeter. These pins are what   I've seen on the internet and I cannot verify them.
   Connecting to constant 12V will allow the maplight to work no matter if   the key is inserted or not. Connecting to switched 12V means that it will   only work if the key is inserted.  I decided to grab constant 12V from the side lamps. I   wanted constant 12V so the light will work at any time.
         Solder wire to the lamp like this picture shown or crimp   to the corresponding wire. I prefer soldering because I don't trust crimp   connectors. The red wire is to the right and the black wire is to the left.   The camera didn't pick up the colors too well in this shot.
         Pull out the old mirror by firmly grabbing the base of it and twisting   downwards. It is held in by tension.
   Route the red (12V) and black (GND) wires through the ceiling over to the   mirror area. I had to pull down my door trim but the routing process was   easy.
         Grab the wires with the female pins that you soldered   together and route them through the large hole and the smaller hole to the   right.
     Plug your pins into the BMW connector on the maplight. The red wire (12V   goes toward the curved end of the connector. Make sure the pins are in   solidly and wrap it all with some electrical tape for extra strength and   piece of mind.
   Install the new mirror by inserting one side and then pushing the other   side in. You'll probably see how it works by the time you take the old mirror   off.
   Solder the wires from the connector and the wires that were routed from   the lamp together. Red to red. Black to black.
         Reinstall the panel and test your maplight.
         Adjust the know that pushed against the windshield until   the unit feels tightly secured. If it shakes while driving, adjust.
        Difficulty:
1 /5
  Performed:
08/08/2004
  Disclaimer: I am not a professional mechanic. Information this page should be used at your own risk and discretion. Different models and model years may be different than my 1991 318i. Read: If you screw your car up following my instructions, sorry. Isn't it sad that in this sue crazy world you have to put a disclaimer on your web page?
romeomike
« Reply #1 on: January 22, 2011, 11:44:58 AM »
I was unlucky to pull off the rectangular mounting frame the old mirror was plugged into. A drill and two self-tapping sheet metal screws saved the day.
I put my 12V lead in the back of the check panel connector--the mirror lights will have power when the key is in accessory or run, and that was good enough for me. You may want your battery disconnected if you're wiring it this way, as you may trigger an SRS fault, and then you're fishing for a non-SRS check panel at the salvage yard.
« Reply #2 on: January 22, 2011, 07:34:29 PM »
Good tips.  I've pulled the roof mount plate out of a few e30s myself.
