Author Topic: Ground control adjustables  (Read 3175 times)
FunfGang
« on: December 26, 2010, 07:42:59 PM »
http://www.modacar.com/bolt-on/products/Ground_Control_Adjustable_Coilover_Springs_84_91_BMW_E30_Drop_0_to_1_75-7512-1654.html I already have Bilstein shocks and HR sports prings, Im just trying to figure out if i could use these w/ out any additional modification. Any help is greatly appreciated.
« Reply #1 on: December 27, 2010, 07:21:32 AM »
I don't have any idea personally, but from what I've seen almost everyone cuts the stock spring perch off to allow more adjustability and choice with wheel selection.
Here's a 5-lug swap that features the Ground Control setup:
http://www.davelength.net/car/5lug.html
ClassicSkril
« Reply #2 on: December 28, 2010, 07:40:30 PM »
call up ground control and tell them what shocks you have. They have set's that are made for certain shocks like tokico for example. The sleeve needs to fit the shock shaft. But yes like dave said you will need to cut the spring perch to get maximum adjustment
