Author Topic: S50B32 Driveshaft in M42B18  (Read 1825 times)
M42_Jester
« on: December 12, 2010, 07:20:39 PM »
I'm sure this topic has already been discussed, but how would one go about doing it? according to RealOEM.com, the S50s driveshaft is shorter than the M42s...is that simply because the Diff is longer in the S50?? or does it have something to do with the transmission?
just racking my brain really...but when i do my engine swap to the MM 2100FI M42, i'm planning on going with one of their LS Diffs aswell...and it stands to reason that if i can put the S50 driveshaft on it, then i can also use a LS Diff that would be used on the S50...thinking their 3.46 LTC Diff would do the trick...
any help would be great guys...
Cheers,
Jester
