The facts:
New battery 3 months ago
Alternator rebuilt 3 months ago
(unrelated, hopefully, but)
New starter 2 years ago
New starter solenoid 1 year ago
Problem:
After starting engine, the alternator/battery light stays on until revved over 1500-2000 rpm. Sometimes, starting sounds labored like the battery is dying but always starts. At idle, turn signal makes dash/OBC lights dim in sync with signal.
Observation/measurements:
After sitting overnight, battery voltage 12.4V.
Immediately after starting (engine @ idle), voltage measured at battery/alt output: 12.8V (alt light on at this point)
Rev engine to 1500-2000rpm, alt light goes out, 14.4V measured at battery
Return to idle after revving past 1500: 14.4V measured at battery and alt light stays out
I also within the past year replaced the alternator adjustment mount and the associated toothed bolt. I get that damn thing as tight as I can get it, and half maybe an inch of belt deflection (?)
What am I missing? What else to check? What am I doing wrong?
BTW: Car is bone stock electrically except for a Sirius receiver I hardwired to the cig lighter wiring.
