DIY - Rebuilding the Driver's Side Door Lock
Author Topic: DIY - Rebuilding the Driver's Side Door Lock  (Read 4592 times)
« on: November 26, 2010, 02:00:48 AM »
I just did this today and put up a how-to article for it. Check it out!
http://bmw.e30tuner.com/articles_lockrebuild.php
monty23psk
  • -Receive: 17
« Reply #1 on: November 26, 2010, 07:31:35 PM »
Awesome. Isn't that kit the best? Now everything works like it should. My arm just broke on the cylinder. I just did this the past Sunday. I still need to do passenger side. I just has an issue with my key as it had been dulled out at the tip.
spanish_pants
« Reply #2 on: December 02, 2010, 08:31:46 AM »
I have a problem with my drivers side doorlock. When i insert the key and turn it clockwise, it turns but doesn´t lock the door. It seems to catch at a certain point but then continues to turn.
When i turn it counterclockwise it opens the lock. Could this fix deal with the problem?
monty23psk
  • -Receive: 17
« Reply #3 on: December 02, 2010, 09:10:50 PM »
Quote from: spanish_pants;99229
Yes, the little arm on the back is probably missing and not making contact against switch. Take door panel off and use a flashlight to take a peek.
kaiser16
« Reply #4 on: January 18, 2011, 09:15:56 PM »
I will give that a try, great right up! My other problem is that my key is so rounded off that I am worried that it won't work any more unless I get new cut keys with this, suggestions??
:D Freude am fahren! :D
monty23psk
  • -Receive: 17
« Reply #5 on: January 18, 2011, 11:45:18 PM »
Mine was rounded off and had issues with the new lock. Luckily I had a spare in better shape. I make a copy of this and use the spare as my regular key as I know my spare works just fine. Took the opportunity to get the lighted key from BMW. Nice subtle upgrade.
