Author Topic: Injectors suitability  (Read 4286 times)
Janne
« on: November 23, 2010, 02:23:15 PM »
Do this injectors: Bosch 0 280 155 712 pass to e36 m42 motor?
deekay
« Reply #1 on: November 23, 2010, 09:12:11 PM »
at 3bar fuel pressure they'll be good for ~17.5lb/hr - double-check what the impedance is, a quick google didn't come up with anything for me
nuvolarossa
« Reply #2 on: November 24, 2010, 11:56:57 AM »
search here, there are specs of m42s and those your wrote:
0-280-155-712
http://users.erols.com/srweiss/tableifc.htm
edit: what you want to know exactly? if they fit physically or if the flow would be enough for your dbilas? :)
« Last Edit: November 24, 2010, 12:02:56 PM by nuvolarossa »
Janne
« Reply #3 on: November 24, 2010, 02:10:50 PM »
Quote from: nuvolarossa;98947
0-280-155-712
I want know do them pass physically to m42? They flow little bit more than stock injectors 190ccm vs 204 and both are four pinttle injectors and high ohm.
And yes, my problem is lean afr with Dbilas itbs and grinded intake-cam. I tryed S50b30 240ccm injectors but car doesnt work with them. It runs too rich and run very very bad, sound like 2-stroke motor and smell like fireworks.:mad:
I think i buy them (204ccm) and try if it works finally:cool:
  • -Receive: 5
« Reply #4 on: November 25, 2010, 03:08:27 PM »
They work on the E30 M42 but the E36 94+ has the stupid air shroud injectors.
http://www.motortraders.net.au/groups/group.asp?group=1&menu=88
So I don't know.
Janne
« Reply #5 on: November 26, 2010, 09:34:52 AM »
Quote from: tjts1;98992
So I don't know.
I dont know why, but i dont have air shroud injectors and my car is e36 07\94. I have "normal" style injectors in my car, so they should fit:cool:
deekay
« Reply #6 on: November 26, 2010, 08:52:36 PM »
Quote from: Janne;98952
i'm surprised to hear that... i had to go all the way up to 24lb/hr injectors, with a slight bump in fuel pressure, to get my car to the 12.8:1ish AFR MarkD said was best for the M42.
ziedas nr 1
« Reply #7 on: November 27, 2010, 05:17:14 AM »
So I don't know.
these injectors,only have a m44 engine,in m42 normal injectors.
  • -Receive: 5
« Reply #8 on: November 27, 2010, 11:21:29 AM »
Quote from: ziedas nr 1;99030
As previously mentioned, they were also installed in 94+ M42s depending on which market you were in.
