Euro sides and clears added
Author Topic: Euro sides and clears added  (Read 4559 times)
FL318is
« on: September 19, 2006, 10:13:23 AM »
Heres a couple of pics with the newest appearance mods.
1-I replaced the running light sides with the euros.
2-Also replaced the amber turn signals with clears and painted the amber bulbs with high temp silver.
3-On the front bumper segment where the tag frame goes, I plugged the holes with plastic caps.  Got the caps at a electronics surplus store for 40 cents.  Used clear silicone caulk to hold them in place.
« Reply #1 on: September 19, 2006, 10:18:08 AM »
looks nice, I considered the clears
FL318is
Thxs
« Reply #2 on: September 19, 2006, 10:23:05 AM »
I wish I could find them for the rear in the same style as OEM.  I think someone on the board may have a set.
« Reply #3 on: September 19, 2006, 10:30:02 AM »
bout a year ago on R3V someone was selling some tails just like stock but had clear instead of the amber turns.  They were hawt!!  They wanted like $400ish IIRC.  I just went smoked all the way around.  I like the clear look too though ;)
FL318is
I will look
« Reply #4 on: September 19, 2006, 10:49:58 AM »
I like the smoke look.  I decided to paint (later) the black trim white so clears are the first phase.
BTW, why do some of the E30s have the side marker turn signal?  Mine is a 1991 as far as I know.
« Reply #5 on: September 19, 2006, 10:53:59 AM »
I added the repeaters, I like the look and the extra function to let dumb drivers know I am going to turn.  It helps stand out a lot, expecially at night.  I got the clears instead of the smoked ones to help w/ the contrast.  There are ones for the e30 that are slightly larger than mine, mine are off a e36/34...
The e36 ones are more slim than the taller e30 ones.
FL318is
Cool
« Reply #6 on: September 19, 2006, 10:59:06 AM »
They look great!  I may do that later on.
« Reply #7 on: September 19, 2006, 09:03:35 PM »
Good to see clears turn signals for a change.
FYI, bmp or bavauto sells front plate fillers as an alternative to the plastic caps. You're going to have to do some searching as I couldn't find it myself. Here's what it looks like (on Digitalwave's car)
FL318is
I Knew It!!!!!
« Reply #8 on: September 20, 2006, 08:39:05 AM »
LOL, I called them and they could not find it.  I was told it is was prob no longer stocked.  I will follow up.  Thanks for the confirmation.
« Reply #9 on: September 20, 2006, 11:44:43 AM »
man am I glad my car had one of those plate fillers when I bought it.  Everyone trys to get them.
« Reply #10 on: September 20, 2006, 01:05:18 PM »
Quote from: FL318is
You could test your luck with BMA :)
M42boy
« Reply #11 on: September 21, 2006, 10:49:41 PM »
Lookin good my man!
