Author Topic: '94 318i M42 loosing water  (Read 2959 times)
deepstuff
« on: November 10, 2010, 06:18:26 PM »
Hi,
  My '94 M43 appears to be blowing water (coolant) out the exhaust.  I don't see any blackening of the remaining water or see any water in the engine oil?  Could it still be a head gasket?  What else could it be?  Is there another way that it could be getting to the exhaust?  I'll pull the plugs tomorrow and see if there's a difference between them?  Are head gaskets or anythung else that could cause this a common problem for these engines?
Thanks,
Hodge
« Reply #1 on: November 11, 2010, 07:29:54 AM »
Are you sure it isn't just water from the exhaust itself? Has it been sitting awhile?
If coolant is getting through the exhaust, it will be a headgasket, since there really isn't anywhere else for it to enter the exhaust.
1995 E36 318isc
ziedas nr 1
« Reply #2 on: November 11, 2010, 10:51:37 AM »
there did you com from? deepstuff
deepstuff
« Reply #3 on: November 13, 2010, 05:34:25 PM »
All spark plugs look the same.  As background the car sat for six months or more before this.   No external leaks.  I've marked coolant level to see if it as moved when it cools down.  Coolant also looks clean?
