Sorry guys, Work has been more then hectic lately.
Something I neglected to mention in my original post, the vibration began after taking a 500km Trip (250 There, 250 Back). At an average speed of about 140 km/h.
My original thought was the differential, because the plugs are both practically seized in. I had not checked for level, ever on this car (1.2 Years of Ownership). Also it leaked from the bottom of the diff plate. So I figured I ran it dry and ruined the axle gears or something. Anyway I digress.
Tonight after work, I tried what nicknikolovski suggested. When jolting my wheel to the left the vibration goes away for that split second of weight transfer. When to the right the vibration is unaffected.
Leaving me to think a wheel bearing is begging for replacement. Question would be which side? Taking into account my suspension is quite soft and worn, when moving my steering wheel to the left in quick motion, the weight of the vehicle would be shifted to the right side of the vehicle, correct? Assuming I have that correct, the problem would most likely be a right side issue?
A thought just crossed my mind, last weekend I finally had a chance to install my new cross drilled rotors and some fresh new pads. Though oddly my front passenger side has a odd kind of a cling clang of a loose bolt type of sound when I go over bumps. Ive thoroughly checked and rechecked for loose bolts, bad pad springs, loose mounting brackets, slide bolts are all thread locked. I cannot figure out where this sound it coming from but its quite unnerving. Could this be the possibly sound of a bad front right wheel bearing?
