Author Topic: powerflex  (Read 5158 times)
romkasponka
powerflex
« on: September 15, 2006, 08:46:59 AM »
E30 318is M42
E36 318is M44
powerflex
« Reply #1 on: September 15, 2006, 09:57:53 AM »
They make good stuff man. My friend has been using they're bushing for years!
romkasponka
powerflex
« Reply #2 on: September 15, 2006, 10:49:43 AM »
I would like to replace front suspension bushings with eccentric bushings. So I wonder, are they without holes unlike stock?
E30 318is M42
E36 318is M44
powerflex
« Reply #3 on: September 15, 2006, 01:11:38 PM »
Quote from: romkasponka
you can get a set of E30 M3 offset bushings...the powerflex bushings are urethane..they might make funny noises.
But yes, they are a solid mount...no holes.
I've got E30 M3 offsets on mine btw and f'in love em.
thumper3ld
  • fathead ***
powerflex
« Reply #4 on: September 15, 2006, 02:30:40 PM »
Quote from: dude8383
Yo,
with the offset bushings, which way did you put the hole? towards the outside, inside, top, or bottom?
powerflex
« Reply #5 on: September 15, 2006, 02:51:46 PM »
Quote from: thumper3ld
Yo,
there are arrows on the bushings and on the lolli-pop. i believe they point in opposite direction of each other. again, the arrows show the proper fitment.
« Last Edit: September 16, 2006, 02:31:14 PM by dude8383 »
romkasponka
powerflex
« Reply #6 on: September 15, 2006, 04:53:00 PM »
ofset is for bigger caster..
E30 318is M42
E36 318is M44
318-is
powerflex
« Reply #7 on: September 16, 2006, 12:49:09 PM »
I have these on my control arms, the m3 eccentric ones. Can recommend them thoroughly, no problems yet. ALthough i will point out, when pressing them in, the left bush goes on the right and the right bush goes on the left. If your pressing them in yourself youl realise what i mean when you do them! Good mod though people and a common problem that causes nasty steering/suspension niggles:
mounted to alloy arms:
powerflex
« Reply #8 on: September 16, 2006, 02:31:43 PM »
yeh, i did the bushings sometime ago...i haven't looked under there since.
cristimm
powerflex
« Reply #9 on: April 08, 2010, 10:09:30 AM »
There are also available a type of M-power OEM centered bushings: bmw code 31129069035.
1991 E30 M42
powerflex
« Reply #10 on: April 08, 2010, 11:52:20 AM »
you do realize this thread is almost 4 years old
