Author Topic: DesktopDave  (Read 68723 times)
Re: DesktopDave
« Reply #75 on: September 13, 2013, 04:01:20 PM »
I've been sloppy about posting updates, here's where I am now.
The white car is still running well.  I've fixed the leaking brake booster...it had three problems.  Both pressure switches were leaking, a hose was pinched against the brake "bomb" and the ATF was fairly low.  Happily, the rest of the system was OK AFAICT.
Still haven't fixed the reverse light switch, and the HVAC system has to come out.  Most of it was in decent shape, just a few leaking hoses.  I think the short shifter has to go as well.  I hate it!
All in all, she's been a fun project.
Re: DesktopDave
« Reply #76 on: November 17, 2013, 06:10:55 PM »
Got some time to work on the car this week, figured I'd post another update. I've just come back from North Carolina; we spent Veterans Day there with my brother's family and the car didn't miss a beat over the 1000 mile round trip. I even sold some BMW parts while I was down there! I was trying to talk him into a pick-n-pull run. Despite it being only five minutes from his house, he declined. He has really nice cars, can't blame him.
The most annoying problems with my car were the warped rotors and dead odometer. I bought a few cheap rotors from RockAuto and a pair of Ebay odo gears.
Figured I'd do the easy job first. I'm down to my last spare cluster, a 325i MotoMeter unit. I decided to take the best of both and make one functional set. I started off on Friday...dismantled the speedometer, added nearly 200K miles to the odo to synch it up with my 'best guess' mileage (based on fuel receipts). Then I swapped the tachometer, SI board and coding chip into the MotoMeter unit & reinstalled it. Annoyingly, the odo refused to work and now the "brake lining" warning light is on. Worse, the fuel gauge needle always read 1/2 (low fuel light still worked though). The M20 fuel gauges use two senders in the larger 63L tank - they're incompatible with the M10 or M42 versions.
So out came the cluster again last night. I installed the odo repair gear in the original odo, updated the mileage, then popped it into the MotoMeter unit. I also added the M42 fuel gauge, then reinstalled it. All functions work! Just have to troubleshoot the flaky brake lining light. As a bonus, the MM cluster has a near-perfect cover, and I prefer the little MotoMeter logo in the middle of the gauges. Betcha I'm the only M42 guy sporting an MM cluster!
Figured I'd tackle the brake lining light today. Neither of those crappy little rotor bolts would come out. I hate the useless old-style E-Z outs. To top it all off, I even broke a brand new Titanium nitride drill bit.  >:( So I left it as-is & installed the new rotors with my current Textar pads. They grind a bit despite having plenty of pad, I'll wait & see if they break in eventually.
Re: DesktopDave
« Reply #77 on: December 08, 2013, 06:07:56 PM »
Wish I could have installed some new brake lines today! Mine are original to the car, and badly cracked. So I ordered some new vinyl-coated stainless flex lines from ECS. They're on sale, look nice, they even match the car! The set of six was only $75 to my door.
In other news, I rebuilt a dual-throw vacuum servo for my E23. They said it couldn't be done! Check it out before & after:
Compared to the relatively simple cable-operated/electrical servo E30 HVAC unit, the E23 vac-servo HVAC system is a real handful! If there is any major vac leak the system defaults to defrost. There are six or seven servos with individual vac lines running off a central manifold with a remote reservoir. Plenty of places for leaks (the most useful tool for testing is a Mity-Vac, LOL). It's very similar to Mercedes-Benz's system. To make things worse, there was not one but two different vacuum-operated systems installed in the E23s depending on market. My grey market Euro model has the so-called 'manual' system. It's the least-well-documented one. E23s sent to our market ran a (somewhat) automatic system. In fact, the diaphragms I've installed are aftermarket replacements for Behr's better engineered M-B system.
I ended up just brushing some snow off the poor cars. It's supposed to warm up for a bit tomorrow; I'm hoping to get the front lines installed then.
« Last Edit: December 10, 2013, 10:22:46 AM by DesktopDave »
Slowered318
  • -Receive: 9
    • My '91 318is
Re: DesktopDave
« Reply #78 on: December 09, 2013, 09:13:15 AM »
I hope these brake lines are as good as they look, I jumped on the bandwagon and ordered some too.
Also noticed that ECS is selling Genuine BMW Anthrazit floor mats under PN 51471911407. It will definitely be nice to have proper floor protection again.
Jumping back to your previous post. Do you know what gauge cover/front is the best to use and where I might be able to order one? Mines taken a beating from a rookie gauge ring install and countless times dragged over the steering column.
Re: DesktopDave
« Reply #79 on: December 10, 2013, 08:24:22 AM »
I have no idea - I just assembled the cluster by selecting the best parts I had sitting around.
Now that I have two heavily scratched spares I might try my hand at plastic refinishing. Further down the road it would not surprise me if a Chinese company produces an economical replacement cover. They're quite enterprising at stuff like this.
Warning...non-BMW content!
« Reply #80 on: February 06, 2014, 07:29:42 PM »
Figured since it's winter, and there isn't a lot of other stuff going on with the cars, I'd do a post about the bikes.
I just picked up a little motorcycle project. It's an '86 Kawasaki Eliminator 600. Nice little bike, all things considered. I'm planning on a quick restore & flip come springtime. The better-known Ninja 600 shares its motor with this bike, but smaller carbs and different cams give more low-end torque (at the cost of some high-end power). The Eliminator chassis likewise has far less sporting specifications. The Eliminator is retro throwback too - just the way I like it.  ;D It's a very 80's style, the so-called "drag bike."
So it's old and a bit ugly, but there are some definite advantages. A heavily staggered seat in a cruiser-style frame with a short 15" rear wheel makes the saddle height very low - they claimed 28". The water-cooled inline-4 running a wet clutch to a shaft drive is robust, reliable and easy to maintain. Kawasaki puts a lot of effort into clever engineering & race track testing. While it's not one of the fastest machines ever built, it'll eat many much larger V-twins for lunch. If you've never been on a bike before, the whining snarl of an small-bore inline four running all out at 9K or so is a treat! Four tiny carbs make for a wee bit of cold-bloodedness, but once it's warmed up the responsiveness is superb.
In the first pic you can see most of the current fleet - my 745i, 318i, Eliminator, and the wife's Mazda MPV (in motorcycle carrier mode). All surround the recently-rebuilt "Fort Puddles." Not pictured are a few of the other bikes - a '95 Interceptor 750 and two big old Honda 1100cc V4 bruisers.
« Last Edit: February 06, 2014, 07:38:40 PM by DesktopDave »
Beeker1972
Re: DesktopDave
« Reply #81 on: February 06, 2014, 09:02:54 PM »
oh no say isn't so!!!
jolle21
  • -Receive: 7
  • hand_built
Re: DesktopDave
« Reply #82 on: February 09, 2014, 11:57:47 AM »
Very nice!!
It's very 80s...I just pictured scenes from Karate Kid and The Lost Boys lol.
Hopefully you can flip this puppy fast. Good luck with the refresh/restoration. Keep us updated!
Aveet C.
- 1980 BMW 320i - M42
Re: DesktopDave
« Reply #83 on: February 09, 2014, 08:38:42 PM »
I just got it running! Of course it's leaking fuel from every carb, but this is definite progress.
It's a NOISY little puppy too - those aftermarket F1s mufflers are not quiet. The motor has a downright mean little growl (which I love) but I hate loud bikes. I think four carb overhaul kits (from my local Harley-Davidson dealer) will get her back on the road. Many Harleys from the 90s use the same Keihin CVK carbs, and their prices are far cheaper than the Kawasaki dealers.
keflaman
  • -Receive: 35
Re: DesktopDave
« Reply #84 on: February 09, 2014, 09:01:01 PM »
That's something I never thought I'd hear.
Re: DesktopDave
« Reply #85 on: February 09, 2014, 09:39:12 PM »
You're telling me. I could not have been more surprised when I consulted for a local H-D dealer. They were quite professional, very competent and good to work with. They're also hard-core bikers all the way - nobody gave me any flack for riding a Honda. Spare parts are very reasonable too.  They do make nice bikes, but they underwhelm me. V-twins just aren't all that exciting. H-D makes their money off merchandise - clothing, chrome and "performance" upgrades are quite expensive. OTOH, their riding gear is a joke, IMHO. It was all made of very high-quality materials, here in the US, and looked great. However, my bargain-basement $40 Fieldsheer textile jacket gives better protection than the $300 Harley leather jobbie.
They also speak a different language. Here's an example:
I needed some fork oil. It's made in single viscosity types (5wt, 7.5wt, 10wt, etc.) so you can 'tune the forks.' Thicker oils will stiffen up the front forks, all other things being equal. It's also pretty expensive oil. So it's important to know exactly what you're getting. I asked the parts guy what weight it was. He looked at me like I was daft, picked up the bottle and read the label to me. "That's Heavy Duty fork oil." :o Well then, I stand corrected! I'll just fill up my "Screaming Thunder" "Performance Racing" H-D forks (made in Japan) and make the potholes scream for mercy under the thundering hooves of my Harley!
Speaking of that, you might not believe this, but my Hondas also use the EXACT SAME 41mm Showa forks that most Harleys use. They have some additional chrome (of course), and less tech, but they're the same mechanism. I've considered swapping 41mm tubes from a Harley, because they're cheaper than the Japanese equivalents.
I've been to a good many Honda parts counters...let me tell you, Harley's service & parts guys left them all in the dust. Having said all that, I'll leave H-D riders for a different day...they are quite the mixed batch!
keflaman
  • -Receive: 35
« Reply #86 on: February 10, 2014, 11:17:12 AM »
I know all too well what you're talking about. I have a '95 FLHT that I've done quite a bit of work to, but that bike is to a Twin Cam now what a Pan Head was to me when my bike was new. (Read it over a couple of times and you'll understand).
Used to be you walked in the shop and talked bikes. Now their eyes glaze over when you do that. Last time I went to the local dealership the salesperson was a former pet store owner and had been working there four months.
Argh!!
Re: DesktopDave
« Reply #87 on: February 10, 2014, 05:39:40 PM »
Aha! Another biker! LMK if you have any good routes down your way - I want to take a Civil War history trip down the Shenandoah this summer or next. I'm considering doing it on my Interceptor.
I really do admire Harley's attention to detail. They build bikes to last. My Japanese bikes must be half plastic. That's a big problem, as those parts start out rare and just get rarer. Asian bikes are also a lot less forgiving of careless storage. They kind of dissolve if not stored in climate-controlled splendor. Harley's trump card is their obsessive focus on brand...they took a liability and turned it into a downright cash cow. Honda, among others, could learn a valuable lesson there. My bikes all lack mass-market charm. Every Japanese manufacturer directly copies the Harley, sometimes even down to frame dimensions. Somehow, they never get it quite right. I'm not a cruiser-type guy, but I do have a few favorite Harleys.
Here's my favorite.
I was struck by the blacked-out treatment of a newer model - I think they called it the Nightster? Reminded me of the old XLCR cafe-style 70's bike they made. I've never been on either one, but they both look great. I also like the old Harley Sprints for their sheer exuberant Italian-ness...and the XR1200 looks quite promising...and there's always Eric Buell's tempting little bikes. I could go on, LOL.
Re: DesktopDave
« Reply #88 on: October 10, 2014, 08:54:43 PM »
Guess what showed up today?
My next project...a 1986 635CSi! Zinnoberrot over Llama leather (power memory sport seats too). 73K miles, Florida car, zero rust, un-cracked dash. Bilsteins too. Just needs a motor/tranny & diff! PO spun a bearing in the old motor. It's a shame too, it had been an M88 from an E28 M5 donor. More or less an M6 without the rear SLS and champagne chiller.
« Last Edit: October 10, 2014, 08:59:43 PM by DesktopDave »
deansweet
  • -Receive: 12
Re: DesktopDave
« Reply #89 on: October 10, 2014, 10:11:57 PM »
looks like it'll clean up nicely!
What engine are you putting ib this one?
