Author Topic: Any interest in a single mass flywheel?  (Read 6393 times)
redhead
« on: September 14, 2010, 07:20:00 PM »
I have the coveted m40 single mass flywheel which is only 1lb heavier than the m20 conversion with all things considered (flywheel, clutch disc & pressure plate). Hell of a lot lighter than the stock dual mass FW!
I can include the matching clutch disc, pressure plate and throw out bearing and the benefit is you can use your existing starter motor - no need to find an m20 starter motor & swap pinion gears and all that jazz. I can also resurface it for you if you would like to put on a new clutch.
Will entertain offers.
///M3Mike
« Reply #1 on: September 16, 2010, 10:37:47 AM »
I'm interested, but I honestly have no idea what they are worth here in the states.  I don't want to lowball and get ignored, ya know
jscribble
« Reply #2 on: September 16, 2010, 07:34:09 PM »
Seconded. Also, condition of includable (lol) clutch?
Betty - Sold
Sabine - 2004 325xi
thebutcher37
« Reply #3 on: September 17, 2010, 12:23:48 AM »
aww mangs.... i j ust got my m20 flywheel for my conversion..... and in the process of doing it.... Post a PRICE!:confused:
jou ma se poes in \'n fishpaste jar.
redhead
« Reply #4 on: September 17, 2010, 02:35:28 AM »
I would like to see $165 for the flywheel, clutch disc, pressure plate & throwout bearing - all with ~93,000 miles on it.
The stock clutches on my e30's lasted 160,000 & 194,000 miles with the latter still holding fine when I pulled it - the clutch included should still have some good life in it yet.
« Reply #5 on: September 17, 2010, 01:03:26 PM »
Next time please include a price when making a classifieds post!
redhead
« Reply #6 on: September 17, 2010, 09:45:45 PM »
My apologies, won't happen again gents!
« Last Edit: September 17, 2010, 09:51:53 PM by redhead »
« Reply #7 on: September 18, 2010, 10:42:20 AM »
Quote from: redhead;96679
No worries man!
redhead
« Reply #8 on: September 18, 2010, 05:25:27 PM »
Quote from: jscribble;96634
Picture showing the amount of meat left on the clutch disc, still has some life left:
flywheel surface:
« Last Edit: September 18, 2010, 05:27:34 PM by redhead »
Aus-m42turbo
« Reply #9 on: September 21, 2010, 09:35:56 AM »
Just out of interest. Would a standard clutch for a m42, match up with your single mass flywheel?
« Reply #10 on: September 21, 2010, 12:28:47 PM »
Quote from: Aus-m42turbo;96778
Hmm good question, if its the same size as the M42 (215mm) then it may...
redhead
« Reply #11 on: September 21, 2010, 06:56:08 PM »
I read that the pressure plate is swappable so presumably the clutch disc would match as well?
jscribble
« Reply #12 on: September 23, 2010, 03:11:39 PM »
That would be good to know, as the m40 put out a little less power, so presumably would not hold as well as m42 clutch.
Betty - Sold
Sabine - 2004 325xi
redhead
« Reply #13 on: September 30, 2010, 10:48:50 AM »
Quote from: jscribble;96837
Generally stock BMW clutches are very robust. I can't see that as being an issue, unless you are running a heavily modified engine.
johna
    • My BMW 3 Series Website
« Reply #14 on: October 01, 2010, 07:43:42 PM »
I did the M40 flywheel conversion on my previous 318is and I am sure that the M42 clutch does not fit the M40 fywheel - you must use a M40 clutch. I can't remember all the reasons but for one the M40 clutch has a sprung centre and the M42 clutch does not.
Here's some pics: http://www.motortraders.net/groups/group.asp?group=1&menu=1&article=18
