Hopefully this is the right place for a thread like this.
Anyhow, I just became the proud owner of a 1991 318is with 192k on the odo. I bought it from a friend who'd done quite a bit of repair work to it. It looks pretty good and runs/drives like a champ. My friend replaced most of the suspension parts and lowered it, so it looks pretty good too.
Down here in the humid South, air conditioning is hard to live without. The car has a compressor and all parts seem to be present. But the a/c doesn't cool well at all, and I have a few questions:
1) The compressor pulley looks like it has two belt grooves on it, though I can't see where more than one belt would come from, nor do I see anything that would need to be driven off the a/c compressor pulley. Any good reason for this?
2) When I first turn on the a/c, it sounds like the compressor belt is squealing badly. The compressor does turn, however. Is this the sign of a worn-out or loose belt? My friend told me how to go about tightening the belt.
3) Dad and I tried to work on it Saturday, though the squealing belt was a curious problem. He has all the gauges to check a/c pressures, and initially, the system pressure was high enough to allow the compressor to turn, but low enough to hinder operation. He added some 134a, as that was what was in the system. the pressure got high quickly, and then stayed there when I shut the system off. Is this a problem?
I'd like to get the system working, though funds aren't unlimited right now. Any advice or suggestions would be welcome.
Thank you,
-Bill
