Author Topic: 91 318is 200k --- $2300  (Read 3654 times)
Uber E30
« on: September 10, 2010, 01:04:35 PM »
Hey guys i have a 91 318is in DS for sale. It has 200k, i just replaced the clutch/tob/resurfaced flywheel less then 1k ago. Also replaced plugs, added a COP kit, all new CA's, CAB's, inner and outer ties, front sway links, used e30 m3 rack with PS deleted, new shift bushings, and its lowered. The interior is black vinyl and its super mint except for a cracked dash. I have a NIB water pump/tstat that will come with it as well. The PO put new shocks on but they are garbage and could be replaced(kragen special). I also upgraded to US elips. The car has new front and rear glass as well.
The exterior has some issues, the drivers fender and hood are dented but i have replacements that i will either install or come with it. The drivers door also has a dent where the trim is but i believe that could be fixed with paintless dent removal. The worst issue is that it has a dent in the rear driver fender that would have to have some body work done. It has a hartge rear spoiler and zender (hartge replica) side skirts. The paint is sub par all around.
The engine is super clean, i suspect it may have been rebuilt at some point but im not sure about that. It holds a nice idle, revs like it has 100k, and doesnt burn any oil or have any milkshake action  There is a small oil leak comming from the front profile gasket like EVERY 318is. The leak is very very slow though, about a drop of oil on my garage floor every 2 weeks.(car was up in the air for about 5 weeks and only two drops on the floor)
There is a weird issue where you need to lock the car several times for it to take, i have a door sensor that im going to replace and see if that fixes the issue. Unfortunately the car is salvage title due to theft. They had drilled the ignition tumbler out. I replaced it with a new one matched by VIN from bmw along with a new key cut from BMW.
$2300 firm or trade for a 318ti   - Im Located in San Francisco
Exterior
Damage
Interior
« Last Edit: September 10, 2010, 04:06:38 PM by Uber E30 »
franhiz
« Reply #1 on: September 16, 2010, 02:39:03 AM »
last price? it looks pretty banged up tho.
Eurofreak13
« Reply #2 on: September 19, 2010, 09:02:48 PM »
Pm'd
jscribble
« Reply #3 on: September 20, 2010, 05:40:54 PM »
where does that spoiler come from! I WANT!
Betty - Sold
Sabine - 2004 325xi
