DISCUSSION
Suspension
e36 318is brakes
Topic: e36 318is brakes (Read 2976 times)
nhevynopal
e36 318is brakes
September 02, 2010, 11:26:46 PM »
hey guys i got a question can i swap the brakes from an 96..... m3 to a 93 318is my friend owns a 97 m3 they look alot bigger there stock he bot zimmerman rotors drilled brembo covers looks superb wat would i need and can it be done
chapellej
Jr. Member
e36 318is brakes
September 24, 2010, 11:49:49 AM »
yes you can, but you will need front spindles from the m3 and rear trailing arms from the m3 and upgrade your brake lines to steel braided versus stock. you may also want to upgrade the brake master as well but stock will do it's all preffernce!
e36 m42 project.....
DISCUSSION
Suspension
e36 318is brakes
