Author Topic: Noob Alert: Threadlocker the same as anti-seize?  (Read 3093 times)
gravyface
« on: August 30, 2010, 12:53:29 PM »
Up here in Canuckistan, I can't find Loctite brand anti-seize at Canadian Tire, Part Source, NAPA, and a few small indy shops.  I can, however, find Permatex threadlocker ("medium" strength) in blue, red, etc.
Is it the same thing?  Will use for spark plugs.
Wizard
« Reply #1 on: August 30, 2010, 03:30:33 PM »
Anti-seize and threadlocker are exact OPPISITES...
gravyface
« Reply #2 on: August 30, 2010, 04:38:42 PM »
Ok, so the Loctite Blue line isn't anti-seize then, but threadlocker, and that's a no-no on the ol' sparkplugs then...
The Permatex line looks exactly like the Loctite line... what would be the Loctite anti-seize I should use on my spark plugs?
gravyface
« Reply #3 on: August 30, 2010, 04:43:34 PM »
Screw it.  I bought the f'n torque wrench, might as well use it:
http://forums.bimmerforums.com/forum/showthread.php?t=1209753
Choking Hazard
« Reply #4 on: September 16, 2010, 11:27:43 PM »
Always use a torque wrench on these engines- most are pretty low and you can strip stuff like the valve cover bolts or intake manifold pretty easily...
[SIGPIC][/SIGPIC]-Scott
