Author Topic: Brake fluid reservoir leak  (Read 2740 times)
gravyface
« on: August 26, 2010, 02:31:46 PM »
What I thought was power steering fluid is actually the brake fluid pooling up (see pic)
The leak is coming from the underside of the cloth braided line that runs between the reservoir and into the firewall (red arrow) -- I can squeeze it and feel liquid coming out.  Explains why the brake fluid indicator came on and stayed on this afternoon.
How hard of a fix is this?  My first thought is to grab a hose clamp, but I don't know if the split is too wide (or where it is exactly with the soggy fabric in the way).
Gerta318is
« Reply #1 on: August 26, 2010, 03:59:27 PM »
Gravy,
I had the same issue yesterday ... I cut back the tube and installed a small hose clamp.  The hose is a non-pressurized fitting, so that it shouldn't matter other than sealing the small split.
gravyface
« Reply #2 on: August 26, 2010, 04:13:40 PM »
Awesome, will go do that right now.
gravyface
« Reply #3 on: August 26, 2010, 04:20:39 PM »
Quote from: Gerta318is;95924
Gravy,
Did you bleed your brakes?  Mine feel a bit mushy, wondering if some air got sucked with that leak.
Gerta318is
« Reply #4 on: August 26, 2010, 04:49:06 PM »
yep.  I was power bleeding the brakes when it happened, so I rebled them all.  Brakes seem to work fine now.
