Author Topic: Dbilas ITB's installed  (Read 15849 times)
DutchM42
« on: August 23, 2010, 07:06:41 PM »
After sitting in the garage for a year or so we finally resurrected the 318is of a friend of mine. The reason ? Some ITB's where waiting to get installed.
Also installed the Dbilas airbox. The plenum is not identical to the one made for the E36. There is a little more space to clear the brakebooster.
When finished we had to do a soundcheck :D
http://www.youtube.com/watch?v=RCix8Ue1ubY&NR=1
Next step is the MAF-delete and getting Alpha-N running.
« Last Edit: August 23, 2010, 07:14:17 PM by DutchM42 »
deekay
« Reply #1 on: August 23, 2010, 10:49:45 PM »
congratulate your friend on joining the ITB club for me :D
it is nice how easy they are to install, isn't it?
mine didn't come with that nifty airbox top, but i just got gifted an AFM adapter, so i think i'm putting on my K&N again tomorrow.
enildeR
  • lol ur face
« Reply #2 on: August 26, 2010, 05:20:35 PM »
are you going to do MAS or MAP with megasquirt or diff standalone?
trackjunkie21
« Reply #3 on: August 26, 2010, 09:53:15 PM »
I'm in love, how much did your setup run you?
max123
« Reply #4 on: August 31, 2010, 12:50:47 PM »
Did you have trouble with the ABS, as it looks like the air intake is right where the control box is located?
max123
« Reply #5 on: August 31, 2010, 12:52:32 PM »
Also, I second - very cool.  Can the Dbilas setup run on the stock ecu - ie compatible with throttle position sensor and fuel injection?  Also, what is the power like?
deekay
« Reply #6 on: September 01, 2010, 04:57:31 AM »
Quote from: max123;96096
yes, that's how i'm running it- motronic 1.3 with a markd chip. the stock TPS bolts onto a spot on the end of the throttle shaft.
as far as the power goes, it shifts the band upward kinda like a hotter cam does... i'm still running the stock cams, but the engine is strongest from 4K to 7K now.
Flexz
« Reply #7 on: September 01, 2010, 03:58:19 PM »
this is my car and itb`s ;)
we just wanted to try-fit it before taken the complete engine apart..
installing is not the most difficul thing to do, you only have to understand wich is doing what...
as a matter of fact, this complete intake is less troublesome to take apart than original..
Alpha-N is laying ready for build-in.. but that will be the last phase..
first the engine is going apart..
this probably will also take a year or so.. right now I am very busy taking my engine from my 325i conv apart... also going on itb`s:D
In this e30 I do not have abs... indeed the flowmaster will sit on top of the abs-unit, wich is not very easy to make a nice fit....
but with the loss of the airflowmeter, you won`t be needing it... just some panty`s over the itb`s :p
deekay
« Reply #8 on: September 01, 2010, 04:03:06 PM »
Quote from: Flexz;96138
yeah, i thought the same thing. i was amazed how easy the install went.
congrats... what are the plans for the engine itself?
Flexz
« Reply #9 on: September 01, 2010, 04:03:37 PM »
btw.. it runs on stock ecu... this one runs on a cheap ebay-chip.. but also runs..
idle isn`t what you want it to be.. but with the itb`s you kinda set the idle on the itb`s (by setting them a little bit `open`)
real profit in the power departement isn`t realy the case..
manely because it hasen`t been chipped after the build-up..
but the whole engine is going apart.. so chipping it now is like taking a whore fishing:p
might be fun, but not what you wanted to...
Flexz
« Reply #10 on: September 01, 2010, 04:08:02 PM »
also my opinion... from 5k up it feels alive... underneath it dousn`t feel at all:p
plans with engine:
work on the cil. head.. (flowen)
pressiure valve system gone... mech valve system in...(higher revs!)
about 290 cams..
bore same, but 1.9 krank...
than after fitting itb`s and alpha-n it must run about 8300 revs.. and app. 200/210 hp
max123
« Reply #11 on: September 01, 2010, 06:48:38 PM »
Nice work - if you don't mind me asking what did the setup cost and where did you source it?
Janne
« Reply #12 on: September 03, 2010, 01:30:34 PM »
Does your car" whoosh" like it has turbo and blow of valve, on hard pull after 5000-7000rpm when you shift gear?
My e36is does it with Dbilas itb`s and thats sounds very hilarious:cool:
