DISCUSSION
Electrical
aux fan troubleshoot question.
Topic: aux fan troubleshoot question. (Read 3065 times)
pbgd3skier
Jr. Member
August 15, 2010, 01:26:56 PM »
Good afternoon. Been trying to get my fan going. If I directly apply 12 v to the fan I get it to run one speed. I cannot get it to run moving to the other terminal. I suspect this means resistor.
But if I jumper at the thermostat switch it pops the fuse. Is this common with bad resistor. It won't run low speed and I suspect that's why it won't start high speed with out blowing the fuse. Reasonable?
1991 BMW e30 318i
1980 BMW R80/7
E30_80Y
September 22, 2010, 12:41:52 PM »
good question, bump. this would somewhat help me too.
Administrator
Legendary
-Receive: 60
Lives in the 80s
September 22, 2010, 02:53:47 PM »
Yep, your resistor is bad. I'd say it's shorting internally to blow that fuse.
The motor works the same either way, the resistor bleeds off power as heat to slow the motor down. Sloppy system, but cheap & reliable.
inarticulate is
September 22, 2010, 06:10:38 PM »
The fan is such an air blocker I thought I'd try running without one, since original had died. So far so good, over 2 months, engine temp stays constant and my air cond. is working better.:rolleyes:
Administrator
Legendary
-Receive: 60
Lives in the 80s
September 23, 2010, 07:08:29 AM »
A lot of M42'ers have swapped in an electric Spal or Volvo fan, removing one or both stock fans in the process.
DISCUSSION
Electrical
