On a friend's '91 318i which won't rev over 2500rpm once warmed, I am trying to diagnose the problem before spending money for parts.
The vane type air flow sensor reads the following resistance between pins 1 and 2 as I test it off the car.
400 ohms with vane closed, smoothly increasing to
750 ohms at 20 degrees open,
750 ohms at 50 degrees open,
750 ohms at 70 degrees open, and then decreasing smoothly to
350 ohms when fully open.
What have others measured? This doesn't sound intuitively correct, but I wouldn't put it past those Bayerischen engineers to do something unusual.
The temperature resistance was spot on at 70F, and I've got exactly 5v at pin 1.
