Author Topic: Ignition Order  (Read 2532 times)
mwilderl
Ignition Order
« on: August 06, 2010, 10:50:53 PM »
I've just installed an m42 into my e21 320is and am wonder how to determine which ignition wires from the wiring harness correspond to the correct cylinders. I can't seem to find anything about which is which and feel like there is some random thing I'm overlooking. Thanks for any help!
Ignition Order
« Reply #1 on: August 06, 2010, 11:13:15 PM »
My e30 m42 doesn't have different colors on the wiring harness.  If you pulled the wiring from an e36 it'll have color coded wires, same DME pins.  There's a helpful post here.
Trace the black wires from the DME plug:
Coil #1: 25
Coil #2: 52
Coil #3: 24
Coil #4: 51
mwilderl
Ignition Order
« Reply #2 on: August 07, 2010, 01:04:32 AM »
It's the e30 harness, although i have an e36 one laying around. Thanks a lot for the info!
