Author Topic: 6 Button OBC Works, but is not Functional  (Read 3663 times)
esager
« on: August 05, 2010, 04:16:47 PM »
Hello -
My OBC has a good display (no bleeding) and all buttons work when you push them, but the default clock display does not keep time. It is only right twice a day if you know what I mean. I can set the time and then it stays there...no movement. The outside temp reading button functions and it will tell me the proper temperature, but that's about it.
I've searched a bit to try and find a similar solution, but with no luck. Anybody have any ideas or similar experiences?
Thanks!
Eric
esager
« Reply #1 on: August 16, 2010, 10:00:30 AM »
Fixed. Detailed over in this thread:
http://www.m42club.com/forums/showthread.php?t=12039
(basically, I had not returned the OBC to "timetelling mode" from "set mode"
