Author Topic: Coolant loss via overflow  (Read 3556 times)
usaexec
« on: July 22, 2010, 10:52:46 AM »
Recently I have started to lose some coolant in my 1998 E36 Convertable.  They is no leak, the radiator, water pump & all hoses are new.
What I am finding is after I stop a small amount of fluid is condensing out the overflow tube.  Not much, but it adds up so I have to top off ever couple of days.
The temp gauge is working and read fine.
Any suggestions?
jscribble
« Reply #2 on: July 22, 2010, 12:09:32 PM »
Shouldn't that system be closed? You have an external tank, correct?
I'm totally unfamiliar with your coolant set up, and without a model, I can't reference anything for you.
tjts link will be helpful if you have an integrated tank like my e30 does.
Betty - Sold
Sabine - 2004 325xi
« Reply #3 on: July 22, 2010, 06:04:12 PM »
I'm pretty sure all E36 cars had the built in reservoir. The E30/M42 was the first car they used it on as far as I know.
jscribble
« Reply #4 on: July 22, 2010, 09:29:46 PM »
I stand corrected.
Betty - Sold
Sabine - 2004 325xi
WilliamJ
« Reply #5 on: September 14, 2012, 01:39:15 AM »
Quote
Recently I have started to lose some coolant system or recovery tank in my 1998 E36 Convertable. They is no leak, the radiator, water pump & all hoses are new.
Any suggestions?
if you have a problem on your coolant overflow or tank, you could try checking your radiator cap. It is actually sealed and caps are junk. When you get to have a new one always push down hard, like screwing it in or you will have to broke.
