engine cut and miss
Author Topic: engine cut and miss  (Read 2890 times)
elmarkes
engine cut and miss
« on: September 09, 2006, 08:41:04 AM »
Hi my name is marc-andré and i am owner of a bmw 318is 1991.
i have post and read alot on many forum for that problem so.
the car idle is now  750 rpm. i dont know if it suppose to be at 750 or 1000.
if i ride over 3000 rpm the car will start to buck missfiering or someting like this
when the problem start if i release the gas pedal the car will run normaly
if i press to got 3000 or 2500 it will start to buck missfiering and if i press over
the car will going to idle and start to buck and sound like a truck with an engine break
so i have check the black wire box under my intake and its like a new
i have change
-air flow sensor
-crank sensor
-cam sensor
-blue temp sensor
 i am tired you are my last chance before i paid somebody for working on my baby
tks
thumper3ld
  • fathead ***
engine cut and miss
« Reply #1 on: September 09, 2006, 09:22:32 AM »
Quote from: elmarkes
i have change
-air flow sensor
-crank sensor
-cam sensor
-blue temp sensor
tks
Could be ignition coils, I had the same prob. Turned out to be my no.3 ignition coil i think. If they're old, you can replace them all or you can be cheap like me, buy one, and keep switching it to see if the problem is resolved. This last :cool:  method won't help if you have more than one coil bad though.
elmarkes
engine cut and miss
« Reply #2 on: September 09, 2006, 10:04:39 PM »
tks i will try that
christophbmw
engine cut and miss
« Reply #3 on: September 10, 2006, 12:08:46 AM »
Ok, before you go replaceing all the expensive parts, and i know this sound dumb but i used to be a BMW technician. When was the last time you replaced your spark plugs? or your plug wires? Check all your vacuum lines, this sound like it could be a simple fix, dont forget how simple our engines are, check those things and then post back on your findings and we can go from there.
I dont know how many times ive seen people start to throw parts at their car when all it need was some plug wires, or something simple.
thumper3ld
  • fathead ***
engine cut and miss
« Reply #4 on: September 10, 2006, 11:15:35 AM »
Quote from: christophbmw
Yeah, plugs and wires would probably be a good place to start if you havent done so already.
elmarkes
engine cut and miss
« Reply #5 on: September 10, 2006, 02:20:25 PM »
sparkplug are ok all hoses are brand new its the first thing i have done on the car.and wire look good but try to change too
elmarkes
engine cut and miss
« Reply #6 on: September 21, 2006, 05:32:47 AM »
that was stupid as my o2 sensor
i have change this before but that beter now
