Author Topic: upgraded gearbox for m42  (Read 4444 times)
gtatbrissy
« on: July 10, 2010, 08:37:16 PM »
i was just wondering if any knows anything about upgrading the gearbox in an e30 318is m42. i have heard u could put an m44 e36 gearbox in, but would this be any stronger. are there any 6 cylinder gearboxes that fit. i ask this because it seems all the diffs are interchangable, so maybe the gearboxes are as well.
thanks guys
jscribble
« Reply #1 on: July 10, 2010, 08:40:04 PM »
Not all the gearboxes are, but from what I understand, the e36 318is trans are interchangeable with e30.  IIRC, steeper (faster off the line, lower top speed) gear ratios from the e36 box.
Betty - Sold
Sabine - 2004 325xi
gtatbrissy
« Reply #2 on: July 10, 2010, 09:48:58 PM »
do u know if the e36 box is stronger?
jscribble
« Reply #3 on: July 10, 2010, 10:12:10 PM »
I don't know for sure, but I doubt it is significantly stronger. Does anyone know what they put behind the s42 engine?
Betty - Sold
Sabine - 2004 325xi
Hey-u
« Reply #4 on: July 11, 2010, 01:27:17 AM »
Is there a 6 speed that will fit?
jscribble
« Reply #5 on: July 11, 2010, 10:43:39 AM »
Quote from: Hey-u;94542
Hmm. Good question. Looks like it's possible.
e30/e36 discussion
R3V thread discussing 6 click m42
I'm sure someone has a definitive answer.
Betty - Sold
Sabine - 2004 325xi
Romrog318is
« Reply #6 on: July 11, 2010, 10:52:36 AM »
i had an E36 box in mine and yea it was nice while it lasted... i blew it up within 4 or 6 months... but the gear ratios are a little nicer
2nd i could get 69-70 3rd i could get like 106
you can put a GR260 from the 325 and it would work but you would need a different driveshaft or shorten urs, a custom tranny brace, heat and twist ur shift linkage 12*
and yes the gr260 is stronger
no more M42
MikeDE
« Reply #7 on: July 27, 2010, 03:23:03 PM »
For 6spd, the E46 M3 trans will physically fit.  As for clutch/DS/etc, someone has to blaze the trail.  Also, this trans is big and from what I remember, a tad noisy, especially in 1st and 2nd, and notchy.  The 6spd out of the 330i ZHP will also fit.  It's a smoother trans, but then again, somebody has to blaze the trail....or they already have and are too stubborn or selfish to share what they have learned.:rolleyes:
Hodge
« Reply #8 on: July 27, 2010, 07:27:39 PM »
The 250 from E36's will fit and yes it is slightly stronger. It is after all behind E36 325's as well.
1995 E36 318isc
