Check under the the drivers side, there are metal lines run along there, 2 of which are fuel. If they are compressed, it could be reducing fuel pressure at the rail.
How does the engine run below 4k? Smooth idle? How is throttle response?
Coils are also a good idea.
If you haven't done it, do a full tune up. All filters, oil, plugs etc. Check for cracked or melted plug wires, loose wire connections (anywhere), and test voltage with the car running.
Any fault codes?
