Author Topic: Kompressor with M42  (Read 3955 times)
bazzi
Kompressor with M42
« on: June 21, 2010, 07:13:13 AM »
Hello all,
I have a question. Does anyone of here experience of buildings in the air kopresor E30 M42? Really that's the thinking I do not know what I expect any problems. For all advice and comments many times thank you.
What I have learned enough pressure 0,3 bar, so it faded original unit injectors and pump.
Important issue is about how to solve the problem in a vacuum for the brakes ....
Thanks for the information
rob_e30
Kompressor with M42
« Reply #1 on: June 23, 2010, 07:49:50 AM »
Vacuum for the brakes is easy... put a check valve in place.  Your car may already have one.  When the engine pulls vacuum the brake booster benefits, but when it generates boost the pressure is blocked from the brake booster.
bazzi
Kompressor with M42
« Reply #2 on: June 24, 2010, 05:41:16 AM »
As I wrote to the PM machuk, I have to buy a compressor EATON MP62 with the following info.t should have some overhead ventyl. It is probably out of things you write ...
photos here:
http://img234.imagevenue.com/img.php?image=03714_Image00002_122_21lo.jpg
