Author Topic: Help - Determining correct coil connectors  (Read 2332 times)
dcroteau
« on: June 15, 2010, 08:37:54 AM »
1991 m42 Engine Replacement under way.
There are no markings to determine which connector coming from the harness is number 1,2,3,4, to the corresponding coil & spark plug wire.
No problem getting the right plug wires identified with an ohm meter.
Anyone know an easy way to tell which connector is which.
The only way I can think of is to trace back to the ECU connector and try and figure it out there with a wiring diagram and ohm meter.
« Reply #1 on: June 15, 2010, 05:01:08 PM »
I was trying to figure this one out for another post...unfortunately the colors are all the same on the e30, but if you pull the DME connector off, you can do a continuity test to figure out the correct wires.
According to this thread, pin 25 is coil 1; 52 is coil 2; 24 is coil 3 and 51 is coil 4.  I didn't have a picture of the connector but the pins should be labeled.
