Author Topic: coolant flow....  (Read 4400 times)
jakeb
coolant flow....
« on: June 13, 2010, 08:53:31 PM »
I was wondering if anyone know the direction of coolant flow in the m42.  Mostly I am wondering about the return line that goes to the overflow tank.  I am wondering if I can plug that.  I am installing a m42 in a 67 BMW and I would like to use the stock radiator, but it doesn't not use a overflow tank.  So I need to find a spot to "put" the return hose.  Can it be plugged or can it go to a T on the top radiator hose?
http://www.classicdaily.net - swapping this into that
http://www.blunttech.com - all your parts needs
BlueBMW
coolant flow....
« Reply #1 on: June 13, 2010, 09:34:09 PM »
I'm not sure on the answer to your question, but when you get it done I'm sure a lot of us would like to see pics of the finished job!  (unless of course you've already posted them somewhere else on this site)
cristimm
coolant flow....
« Reply #2 on: June 14, 2010, 02:25:05 AM »
Quote from: jakeb;93536
On any car the lower hose is the radiator exit and the upper hose is the radiator inlet.
jakeb
coolant flow....
« Reply #3 on: June 14, 2010, 08:31:55 PM »
Does anyone know if the coolant pipe that goes along the drivers side block is just a return?  Or does all the coolant return to the radiator through that pipe to the overflow tank?
Mostly I am wondering if I can just plug that hose (that normally goes to the tank) and all will still work.  Otherwise I will T it back into the upper rad line.
B318M42W
coolant flow....
« Reply #4 on: June 15, 2010, 01:02:03 AM »
why not take the stock M42 radiator and stuff and put it in?
M90 Blown M42 :cool:
jakeb
coolant flow....
« Reply #5 on: June 15, 2010, 06:27:09 AM »
It is a little too big to fit in the chassis that I am doing this swap on.  I have a 2002 with a m42 as well and the m42 rad fits fine but not in this car.
Also I really would like to keep the stock radiator, it keeps things looking more 'stock'
jakeb
coolant flow....
« Reply #6 on: July 07, 2010, 05:46:47 PM »
any one?
one person on r3v said it was the main feed to the water pump...if that is true I need it hooked up.  Can I hook it too the top rad hose, or lower?
jakeb
coolant flow....
« Reply #7 on: July 07, 2010, 08:11:46 PM »
here is a pic of the swap
jakeb
coolant flow....
« Reply #8 on: July 07, 2010, 08:20:52 PM »
Victorymike18
coolant flow....
« Reply #9 on: July 10, 2010, 11:39:21 AM »
It's looking pretty neat and tidy so-far.
Could you take one or two closeup pics of the bracket on the driver side that you have the fuses and (diagnostic?) plugs on?    Looks good.
