do you have trouble with knocking? I did, even when my AFR was spot on, so i had to dial the ignition timing back
at first, with stock injectors - i did have knocking problem.
i tried using better fuel (98 octane instead of regular 95) and it did the trick most of the time.
but final answer to knocking was changing injectors to SAAB 900 turbo ones, which rate 220 instead of the stock 180 injectors.
now my car runs pretty reach most of the times.
another solution can be moving on to >1993 CPU which support knocking sensors and can compensate ignition timing better than pre 1993 ECU - of course this only applies if ur engine block is post 1993 and support knock-sensors as well harness and ECU support those as well.
